    MoveCopy a line BUG?
    4 Posts 4 Posters 376 Views 4 Watching
    • frankflafyF Offline
      frankflafy
      why when
      1.i select a line
      2.i click and move it with ctrl means copy
      3.i put a number , etc 10
      4.enter
      5.it not move or doing anything at all.
      6.i reenter 10. enter
      7.and it move 10 point.
      why i must double entry to copy a line?
        Your description isn't very clear are you actually moving the selected line in the desired direction before typing 10? Maybe you could make a video capture of what you're doing and post it here?
        • mitcorbM Offline
          mitcorb
          Do you wish to copy it 1 time or 10 times or copy/ move it 10 units away?
            Select the edge
            Activate Move + Ctrl
            Pick a start point
            Move the edge in the desired direction
            Type the distance desired + <enter> [say 6]
            The copy of the edge is made moved 6 units in that direction
            Immediately typing another distance changes the moved amount
            Next immediately type the number of copies you want, followed by x and <enter>
            So for 10 copies that'd be 10x
            The moved edge is replicated 10 times in the direction you chose, beyond the first copy, using the same distance each time...
            To copy a number of edges between the original and the first copy's position use /10 instead... then the space between the original edge and the first copy is subdivided with new duplicates, evenly spaced to fit in...
