MoveCopy a line BUG?
 why when
 1.i select a line
 2.i click and move it with ctrl means copy
 3.i put a number , etc 10
 4.enter
 5.it not move or doing anything at all.
 6.i reenter 10. enter
 7.and it move 10 point.why i must double entry to copy a line?
 Your description isn't very clear are you actually moving the selected line in the desired direction before typing 10? Maybe you could make a video capture of what you're doing and post it here?
 Do you wish to copy it 1 time or 10 times or copy/ move it 10 units away?
 Select the edge
 Activate Move + Ctrl
 Pick a start point
 Move the edge in the desired direction
 Type the distance desired + <enter> [say 6]
 The copy of the edge is made moved 6 units in that direction
 Immediately typing another distance changes the moved amount
 Next immediately type the number of copies you want, followed by x and <enter>
 So for 10 copies that'd be 10x
 The moved edge is replicated 10 times in the direction you chose, beyond the first copy, using the same distance each time...To copy a number of edges between the original and the first copy's position use /10 instead... then the space between the original edge and the first copy is subdivided with new duplicates, evenly spaced to fit in...
