    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 384.5k Views 109 Watching
    • OxerO Offline
      Oxer
      Thanks you very much for this useful plugin!! πŸ‘
      It works perfectly on Mac & SU2014. One question, the Row2Row Offset for Brick is 0.5 by default when you use mm units, I changed to 50 in line 69 of the rb file.
      @defaults=["Corner","0","Current","Yes","Yes","50","No","No","0","No","No","30","150","50","12","6","3"] if @@opt=="Brick"
      @pixero said:
      I think you forgot to say that if you place a folder called BTW_Textures in your plugin folder and choose use Apply material: Rand_Tex it will use all textures in that folder.
      Thanks Pixero for the info and Textures πŸ‘
      Another question, what units uses the Texture Size, mm, inches or pixels?
      http://www.oxervision.blogspot.com/
      • sdmitchS Offline
        sdmitch
        Thanks for pointing that out. Originally I was using a fraction(0.5) instead of a %. Once it is corrected from within the plugin and Update is clicked, that should take care of it.
        What ever units you are using in the model, either mm or inches. The API says inches but mm seemed to work for me.
        http://sdmitch.blogspot.com/
        • OxerO Offline
          Oxer
          I use metric units in my models for that, I suppose the Texture Size it will expressed in mm, is it so?
          The Options Window is a bit little on Mac, I changed the window hight to 530 so I can see all options.
          @@dlg=UI::WebDialog.new("FloorGenerator", false,"BTW",300,530,10,10,true)
          • OxerO Offline
            Oxer
            I have created a icon for the plugin.
            Floor Generator Icon
            Icons FloorGenerator
            • KrisidiousK Offline
              Krisidious
              Can we get something like this as a pattern?
              Can you show us some patterns to build for you? let us help.
              3D_Hatching_LedgeStone.skp
              By: Kristoff Rand
              • sdmitchS Offline
                sdmitch
                That pattern is just a bit to random I think. the closest I could get is a random length, width and thickness using the wood pattern
                • pbacotP Offline
                  Still after the holy grail, ay Kris? lol. I am trying to figure out how to do a stone wall surface (with SU hole punch components for windows etc.) and make some sort of detail at the corners that suggests the stone profile...
                  That's not bad sdmitch Should keep looking at it!
                    Krisidious
                    lmao... And I will have it.
                    By: Kristoff Rand
                      Krisidious
                      That looks pretty dame good sdmitch... if I had used a better tiling texture it would look better.
                      By: Kristoff Rand
                      • rvizR Offline
                        rviz
                        1. inconsistent grid origin\rotation (tried on simple cube, see pic.1)
                          By design, the plugin aligns the pattern length with the longest edge of the face picked. In this case, I would undo and redo the face with 90 rotation selected.
                        After 90 rotating the tool takes origins randomly: sometimes it's the upper corner, sometimes the lower one.
                        But the most important: is there place for code optimization? It takes approx 5 min to put 2k tiles (to do it manually would take may be 0.5 min πŸ˜• ).
                        • sdmitchS Offline
                          sdmitch
                          As with any plugin, if you can do it faster manually, then don't use the plugin.
                          If you are using Corner origin, the corner closest to the point on the face that you pick will be used.
                          • zieiosZ Offline
                            zieios
                            love it.... πŸ‘
                            • EarthMoverE Offline
                              EarthMover
                              Drooling. I've been hoping for this for a long while. Thanks Sam. Brilliant work! πŸ‘
                              Content Creator at Skapeup
                              • sdmitchS Offline
                                sdmitch
                                Yet another update!!!
                                  This should be available in the SCF PluginStore...
                                  Is it now 'stable' enough to be added ?
                                  • sdmitchS Offline
                                    sdmitch
                                    Perhaps not just yet. There will probably more pattern options added in the near future.
                                    Is there a way for me to add it to the plugin store or do you have to do that?
                                    • TandemT Offline
                                      Tandem
                                      @sdmitch said:
                                      ...Is there a way for me to add it to the plugin store or do you have to do that?
                                      There really should be a page or topic that explains the process of adding a plugin to the SketchUcation Plugin Store. I have searched the whole site, but could not find anything. Would be useful for developers and end users.
                                      • K Offline
                                        kabezoon
                                        first time it works for me... but now just crush the sketchup, even updating... any help?
                                        http://www.subeimagenes.com/img/captura-953712.JPG
                                          mustafa1972
                                          Hi Pixero
                                          How can I use BTW_Textures textures.
                                          I have copy the file in to the plugin folder
                                          but it dont work.
                                          • sdmitchS Offline
                                            sdmitch
                                            This plugin is still very much a work in progress. We will try to address all suggestions as time permits.
                                            • 16
                                            • 17
                                            • 2 / 17
