    GEO Location grab of map not satellite?
    6 Posts 5 Posters 2.9k Views 5 Watching
      RyanMAS
      Is it possible to to geo grab the map instead of the satellite the image? You can switch in the preview screen but switches back to satellite once you "grab" it. Or just screen shot google maps and bring it in as an image and scale accordingly?
      Trying to do some urban planning mass modeling. Looks like it would be easier using the map. I don't like the casted shadows from the satellite imagery.
      Thanks!
      • U Offline
        unearthed
        If you're just going to grab the image and don't want the data, why not use your local/region council's GIS it's (usually) much more upto date than google's. Shadows are usually less of an issue too.
        Growplan - People ∩ Plants ∩ Place
        windows 7 64b, 4GB RAM, SU 8.0.16846
        Gimp, QGIS, Vectorworks 12, Bricscad 11
          driven
          If you mean like this, I asked before, without response...
          [web 100%,600:idi34omd]http://sketchucation.com/forums/download/file.php?id=76267&mode=view/rokbox.jpg[/web:idi34omd]I manually aligned the map with the "grab" image, then used it as a 'projected texture'
          john
            RyanMAS
            Ooh well done. Did you save the map image from google maps and then scale to fit the "grab" satellite image?
              Aerilius
              There will be an up-coming plugin to do this (import one or several maps from different providers).
                @aerilius
                You tease
