    Speckles in my render.
    renderpluginsextensions
    12 Posts 5 Posters 1.5k Views 5 Watching
    • vagadesignV Offline
      vagadesign
      Hello Guys and Gals,
      I’m Carl, I’m a freelance architectural designer and I guess you could say I’m relatively new to using VRAY and Sketchup; I’ve been using it on and off for the last few years but only to the level of basic model making and basic white studio renderings.
      I’m currently working on examples for my portfolio and my website but I seem to be having issues with my rendered image. There seems to be white dots and speckling at different point of the image and I do not know why this is? Any suggestions would be great. I’m using Sketchup 8 and Vray 2.1 (I think).
      I’ve put some images below of what I mean, but if they don’t show up I can e-mail them to you.
      Cheers
      Carl
      https://www.facebook.com/photo.php?fbid=219040034973222&set=a.219040014973224.1073741828.100006016806408&type=3&theater
      https://www.facebook.com/photo.php?fbid=219040308306528&set=a.219040014973224.1073741828.100006016806408&type=3&theater
        vagadesign
        below are my images for the post above, any recommendations would be great as I dont understand the random speckling.
        • mitcorbM Offline
          mitcorb
          Hi.
          Look at this link to other links and threads:
          http://sketchucation.com/forums/searchgoogle.php?keyword=vray+speckles
          • stefanqS Offline
            stefanq
            Activate sub-pixel mapping and clamp output in color mapping tab. Usually, it works with the white speckles. Good luck!
            • V Offline
              valerostudio
              I agree with the above. I find these appear when I have metals in my scene. Are you using emissive materials at all for your lighting?
                vagadesign
                @stefanq
                Thanks for that, it has definitely made a difference to the renders and now they look much cleaner. Do you know why this occurs?
                @valerostudio
                No I haven't used any emissive materials for anything, well there's an emissive layer on the computer screen in the office image but that's literally it. Would that effect the render? (I dont know a great deal about emissive layers as I'm fairly new to all this)
                • andybotA Offline
                  andybot
                  if you have anisotropy turned on - make sure it's mapped to the Z axis instead of UV...
                    vagadesign
                    @Andybot
                    Cheers Andy, what does anisotropy do? I'm still trying to get my head round all of the terminology.
                    • V Offline
                      valerostudio
                      It's a setting in reflection used to simulate brushed metals.
                        vagadesign
                        Would that cause the effect in my renderings though?
                        • V Offline
                          valerostudio
                          Yes, I do believe I have come across this same issue and that fixed it.
                          • andybotA Offline
                            andybot
                            Yes, it can cause effects like what you see in your rendering. There's a checkbox to use UV, you want to have that box unchecked.
