    Speckles in my render.
    renderpluginsextensions
    12 Posts 5 Posters 1.8k Views 5 Watching
    • mitcorbM Offline
      mitcorb
      Hi.
      Look at this link to other links and threads:
      http://sketchucation.com/forums/searchgoogle.php?keyword=vray+speckles
      • stefanqS Offline
        stefanq
        Activate sub-pixel mapping and clamp output in color mapping tab. Usually, it works with the white speckles. Good luck!
        • V Offline
          valerostudio
          I agree with the above. I find these appear when I have metals in my scene. Are you using emissive materials at all for your lighting?
          • vagadesignV Offline
            vagadesign
            @stefanq
            Thanks for that, it has definitely made a difference to the renders and now they look much cleaner. Do you know why this occurs?
            @valerostudio
            No I haven't used any emissive materials for anything, well there's an emissive layer on the computer screen in the office image but that's literally it. Would that effect the render? (I dont know a great deal about emissive layers as I'm fairly new to all this)
            • andybotA Offline
              andybot
              if you have anisotropy turned on - make sure it's mapped to the Z axis instead of UV...
                vagadesign
                @Andybot
                Cheers Andy, what does anisotropy do? I'm still trying to get my head round all of the terminology.
                • V Offline
                  valerostudio
                  It's a setting in reflection used to simulate brushed metals.
                    vagadesign
                    Would that cause the effect in my renderings though?
                    • V Offline
                      valerostudio
                      Yes, I do believe I have come across this same issue and that fixed it.
                      • andybotA Offline
                        andybot
                        Yes, it can cause effects like what you see in your rendering. There's a checkbox to use UV, you want to have that box unchecked.
