    Exporting channels not working in Vray?????????
    extensions
    13 Posts 7 Posters 5.1k Views 7 Watching
    • maeglin1M
      maeglin1
      THE VSB CHANNELS DO NOT EXPORT IN VRAY 2.0 (SP1) DEMO... accept RGB & alpha.
      Chaosgroup has a 3 day waiting time to respond to problems via email.
      I have to send messages to 3rd party forums and hope for a response....
      • andybotA
        andybot
        sorry I can't help answer any demo questions. But I would suggest you post in the vray sub-section of the forum and maybe someone who knows can help.
        Also, by VSB, do you mean VFB (Vray Frame Buffer)?
        • J
          jakeshin
          did u solve the problem? i'm faced with same problem. if solved, please share the solution..
          • jiminy-billy-bobJ
            jiminy-billy-bob
            It's a limitation of the demo. This is normal.
            • rodrigonotorR
              rodrigonotor
              It's not a demo limitation
              http://www.chaosgroup.com/public_images/V-Ray-2.0024-SketchUp-Features.pdf
              • Sketchando.net • www.arqcad.net •
              • rodrigonotorR
                rodrigonotor
                There is a little trick, but don't know is correct to share. If not, please delete this message.
                The olders version of v-ray have a file vray_SettingsRenderChannels.dll copy and replace C:\ProgramData\ASGVIS\VfS\vrayplugins
                Don't understand why it's not funcionlly in the new version, since it is very useful.
                Regards
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  I'm pretty sure I saw someone from Chaos Group posting that it is a limitation from the demo. Though I can't find this post anymore.
                  What you're refering to in the release notes is that before this release, there were numerous channels that were not yet supported by VfS. A lot of people were confused because these channels rendered black. So they don't display them anymore, until they're supported.
                  • maeglin1M
                    maeglin1
                    Yes, your right. The fully licensed Vray has the ability to individually render channels in the VFS. But, the demo version hides this feature and you can only render Diffuse & alpha channels.
                    • rodrigonotorR
                      rodrigonotor
                      The *.pdf is for the release 2.00.24 SP1
                      • B
                        bitslapped
                        ...vray_SettingsRenderChannels.dll copy and replace C:\ProgramData\ASGVIS\VfS\vrayplugins
                        Worked for me.
                        • rodrigonotorR
                          rodrigonotor
                          Nice 😉
                          Enviado desde mi WT19a usando Tapatalk 2
                          • FlatchoumF
                            Flatchoum
                            HI! I do have the same problem, can you tell me where to find this old version of the vray_SettingsRenderChannels.dll file? Since I don't get an answer from Chaosgroup, I'll have to try the other way to fix it. Thanks
                            • rodrigonotorR
                              rodrigonotor
                              Here are a copy: http://www.mediafire.com/download/hap0k3w50277wi4/vray_SettingsRenderChannels.zip
