    Exporting channels not working in Vray?????????
    extensions
    13 Posts 7 Posters 5.0k Views 7 Watching
      jakeshin
      did u solve the problem? i'm faced with same problem. if solved, please share the solution..
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        It's a limitation of the demo. This is normal.
        • rodrigonotorR Offline
          rodrigonotor
          It's not a demo limitation
          http://www.chaosgroup.com/public_images/V-Ray-2.0024-SketchUp-Features.pdf
          • Sketchando.net • www.arqcad.net •
            rodrigonotor
            There is a little trick, but don't know is correct to share. If not, please delete this message.
            The olders version of v-ray have a file vray_SettingsRenderChannels.dll copy and replace C:\ProgramData\ASGVIS\VfS\vrayplugins
            Don't understand why it's not funcionlly in the new version, since it is very useful.
            Regards
              jiminy-billy-bob
              I'm pretty sure I saw someone from Chaos Group posting that it is a limitation from the demo. Though I can't find this post anymore.
              What you're refering to in the release notes is that before this release, there were numerous channels that were not yet supported by VfS. A lot of people were confused because these channels rendered black. So they don't display them anymore, until they're supported.
              • maeglin1M Offline
                maeglin1
                Yes, your right. The fully licensed Vray has the ability to individually render channels in the VFS. But, the demo version hides this feature and you can only render Diffuse & alpha channels.
                  rodrigonotor
                  The *.pdf is for the release 2.00.24 SP1
                    bitslapped
                    ...vray_SettingsRenderChannels.dll copy and replace C:\ProgramData\ASGVIS\VfS\vrayplugins
                    Worked for me.
                      rodrigonotor
                      Nice 😉
                      Enviado desde mi WT19a usando Tapatalk 2
                      • FlatchoumF Offline
                        Flatchoum
                        HI! I do have the same problem, can you tell me where to find this old version of the vray_SettingsRenderChannels.dll file? Since I don't get an answer from Chaosgroup, I'll have to try the other way to fix it. Thanks
                          rodrigonotor
                          Here are a copy: http://www.mediafire.com/download/hap0k3w50277wi4/vray_SettingsRenderChannels.zip
