    Another Plugin Store Request
    11 Posts 6 Posters 732 Views 6 Watching
    • Bob JamesB Offline
      Bob James
      How about an uninstall feature?
        Plugins > SketchUcation > .....
        Amazing what you find hidden away
          Jim
          Except it doesn't really follow the definition of "uninstall." For most users it's not important. As someone who spend a lot of time in my Plugins folder, it would be nicer if the disabled and uninstalled .rb files were moved into sub-folders rather than having their file extensions renamed. It would unclutter my file browser. This is a request not a complaint.
            Bob James
            Sneaky (being graphically inclined I was expecting a tab), but very glad it's there. Thank you.
            But also agree with Jim, so add me as a +1.
            • BoxB Offline
              Unrelated to Bob's question but it is a request thread so not a bad spot to add it.
              Now that you are working on Bundles is it in any way feasible to add the UI to the bundle.
              I wonder if it is possible to have a plugin that can export all your toolbar positions and shortcut settings etc so that can be added to the bundle.
              True syncing, so you don't have to reorganise your toolbars on each new setup. It would make a great teaching aid knowing your student had the same layout as you.
                We debated a toolbar button but decided that putting an uninstall feature so prominently wasn't needed.
                As per Jim's idea....
                We'll investigate.
                  @Box
                  That's a good idea.
                  Added to the investigate list.
                  Currently we are close to finishing 3.0 which has a more please UI.
                  Also the plugin upload area is getting an overhaul to reflect the API, stats and other developer goodies planned.
                  This hopefully will be previewed mid April.
                  • jeff hammondJ Offline
                    jeff hammond
                    is that even possible? personally, i sync my shortcuts, plugins, materials, and styles via dropbox & symbolic links but syncing the workspace poses some problems due to differing screen resolutions.
                    dotdotdot
                    • mitcorbM Offline
                      mitcorb
                      Hi, Rich:
                      Are you guys considering refinement of the Category search(filter?) in the new version? The listed categories seem too broad, where a particular plugin gets listed in multiple categories, but is probably more one thing than another. Does this make any sense?
                        @Tim
                        We are looking at adding some type of tagging system that Authors can input dedicated sub categories of their choosing.
                        • mitcorbM Offline
                          mitcorb
                          Thanks.
