    Sketchup pro 2014 plugin user
    19 Posts 8 Posters 2.1k Views 8 Watching
    • Denver76D Offline
      Denver76
      Hi!
      can someone help me?
      I'm a win. 7 64-bit. 2014 sketchup pro user.
      but I can not install the plugins, and writes out.
      thanks
        How have you installed these Plugins in v2014?
        If you have manually copied them from v2013, then you have probably missed out vital files or subfolders.
        Causing these errors to pop up!
        You should always install the latest versions of Plugins when you get a new version of SketchUp.
        Many Plugins have been rewritten to be compatible with v2014 and so the old ones can also make errors, even if you haven't made an error in the copying.
        Get the latest Plugins versions from the SketchUcation PluginStore [or ExtensionWarehouse for those - like su_... which are not hosted here]
        If you have RBZ archives you install them using the v2014 Preferences > Extensions > Install... button.
        The EWH can auto-install its contents for you from within SketchUp.
        If you download and install the SketchUcation Plugin Store Toolset [RBZ] from the Resources menu above, then you can then use that to browse/search through hundreds of Plugins and AutoInstall them from within SketchUp itself, then Manage your Extensions and Plugins, AutoInstall RBZ & ZIP archives etc... An impending update to the toolset will even help you 'sync' your Plugins across SketchUp versions and even several disparate computers...
        The tool finds the right locations etc and does everything automatically for you...
        Unlike the EWH/native Installer, the SCF toolset even allows you to AutoInstall into and manage custom-plugins folders other that the default one [e.g. a Dropbox folder setup using Fredo's AdditionalPluginsFolder plugin and shared between several computers]
        This toolset removes the possibility of wrongly copying out of date files or getting the subfolders jumbled etc - everything is done automatically for you.
        Tip:
        If you are installing any of Fredo's and thomthom's Plugins remember that you need to install the supporting 'Lib' for their sets... Clearly liked and explained in the Plugins' main posts, and the latest versions of both Libs are always available from the PluginStore...
        • Denver76D Offline
          Denver76
          I'm not a beginner, but I still do not understand why it does not work.
          SketchUp 8 -2013 had no problems
          • cottyC Offline
            cotty
            The error message contains TT_Lib2 errors, but there are no Thomthom plugins in your plugin folder?!
            my SketchUp gallery
              What happens if you try it on a different user account who's name has no special characters or spaces?
              Sent from my iPad
                Your Windows User-Name contains non-ASCII characters.
                Before SketchUp v2014 came out with its newer version of Ruby this was a known issue on PCs.
                Many Plugins need to write/store files into the User's Temp folder.
                If the path to that contains a special character then Ruby1.8 can fail in some File operations since it cannot find a folder in the path that has an 'accented' name - like your User account.
                I see your example screen-shot refers to v2014 although your SCF User Profile says v2013 ?
                Although v2014 can now cope with accented characters in file-paths, they still need to be UTF-8... what is the character in your name? it is indistinct on my screen.
                Is it 'õ' ?
                What is your locale/language - Hungary/Magyar ?
                Some special-characters might not be recognized by v2014 as being suitably encoded.
                Please try these in the Ruby Console and report back [copy/paste] the results:
                $:.grep(/[Pp]lugins/)
                --> result
                Typically should be:
                ["C:/Users/YourUserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins"]
                pf=Sketchup.find_support_file('Plugins')
                --> result
                File.exist?(pf)
                --> result
                Typically should be 'true'
                pf.tr("\\","/").split('/')
                --> result
                Typically should be
                ["C:", "Users", "YourUserName", "AppData", "Roaming", "SketchUp", "SketchUp 2014", "SketchUp", "Plugins"]
                Any failures with these tests show something is wrong in the way SketchUp v2014/Ruby2.0 is working with your accented user-name...
                If you make another User-account without any accents in the name, then it should then work OK when used with v8/v2013/v2014...
                Please Note:
                A bug has been uncovered in v2014 which should be fixed in the next maintenance release - User-Names containing UTF-8 accents should now be OK, BUT if there's a ' [single quote] in the name it will fail to load any Plugins at all ! So until MR1 is released it's best to keep your Windows User-Name uncomplicated.
                • Denver76D Offline
                  Denver76
                  thanks
                  • Denver76D Offline
                    Denver76
                    I creat the new user account: User / dani
                    Now it works in sketchup 2014
                    thanks for the tip
                    • tt_suT Offline
                      tt_su
                      I just traced down a bug in Ruby that could be related to this:
                      http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=57017
                      If the plugin uses FILE the encoding is marked incorrectly and Ruby will mangle the path when it tries to load it.
                        Major bummer !
                        • arqpadaoA Offline
                          arqpadao
                          Hello guys,
                          I'm with my license 2014 installed and everything seems ok.
                          I tried to install Libfredo 6 + RoundCorner - latest versions and not working.
                          Displays the folders they are installed, but in SketchUp the attached message and nothing appears.
                          Please can someone show me the light at the end of the tunnel?
                          thank you.
                          fernando padão
                          arquiteto
                          porto alegre - brasil
                          http://arqpadao.blogspot.com
                            You must also install LibFredo.
                            It's explained in the tool's first page.
                            You need to restart SketchUp afterwards...
                            Most of Fredo's tools need the Lib installing too.
                            It is available from the PluginStore...
                            It is shown in your list but might have been mis-installed.
                            How did you install the tool and the Lib which is shown in the list ?
                            Using the RBZ and the Preferences > Extensions > Install... or the SketchUcation Plugin Store dialog AutoInstaller ?
                            The installed path to the Plugins folder looks very odd ? 😕
                            If you use this in the Ruby Console is the path that's returned where these files are installed ??
                            • arqpadaoA Offline
                              arqpadao
                              Hello Tig
                              Everything was installed as you said.
                              I downloaded the latest versions, installed via rbz.
                              The files are in the correct folder.
                              And does not work, is giving the information of the previous picture.
                              C 😕 Users / padão / AppData / Roaming / SketchUp / SketchUp 2014/SketchUp/Plugins
                              The possibility I see is that users are not accepted containing names not supported by ASCII.
                              fernando padão
                              arquiteto
                              • fredo6F Offline
                                fredo6
                                That must be the problem (i.e. non-Ascii name).
                                Thomthom has signaled the problem (which is in variable FILE) and suggested a fix, but pending further investigation.
                                Fredo
                                  @padão
                                  As Fredo says...
                                  Accents [non-ASCII characters] in file-paths always broke earlier versions of SketchUp on PCs.
                                  With v2014 the newer Ruby2 ought to resolve this, BUT it was discovered after it was launched that the current version still breaks the reading of the __FILE__ variable in some circumstances.
                                  Your Plugins folder-path includes pad**ã**o
                                  So that accented character is almost certainly what's causing the issue.
                                  Thomthom came up with a temporary fix and the next maintenance release of v2014 will hopefully resolve this limitation...
                                  Until then you could try this temporary fix:
                                  Edit the two Fredo files with Notepad/Notepad++ and find where __FILE__ is used.
                                  [You'll also need to repeat it in any other Fredo tool's rb files you use]
                                  Change:
                                  Fredo6_!LibFredo6.rb Line#113 @lib_fredo_sudir = File.dirname __FILE__
                                  to read:
                                  if defined?(Encoding) @lib_fredo_sudir = File.dirname(__FILE__).force_encoding("UTF-8") ### v2014 lashup else @lib_fredo_sudir = File.dirname(__FILE__) end
                                  AND in:
                                  Fredo6_RoundCorner.rb Line#26 f6__file__ = __FILE__.gsub(/\\/, '/')
                                  becomes:
                                  if defined?(Encoding) f6__file__ = __FILE__.force_encoding("UTF-8").gsub(/\\/, '/') ### v2014 lashup else f6__file__ = __FILE__.gsub(/\\/, '/') end
                                  It that works let us know 😉
                                  • tt_suT Offline
                                    tt_su
                                    Yes, FILE in SU2014 will not have the right encoding for Unicode characters. At the moment forcing the encoding works - but I cannot guaranty that will work in the future. We've filed bugs with the Ruby developers and once a fix has been implemented in Ruby we can give better recommendation on how to handle this.
                                    So forcing the encoding works for now, but developers beware that this might need adjustment in the future. You might want to wrap the fix up in a utility function you can quickly edit later on.
                                      matiu
                                      need to update libfredo to 58. Where can i get new version??
                                      how do i update??
                                      • fredo6F Offline
                                        fredo6
                                        The best is to update via the PluginStore tool
                                        Otherwise, go to the LibFredo6 Thread.
                                        Fredo
                                        • arqpadaoA Offline
                                          arqpadao
                                          Thanks guys, I'll try and see what happens.
                                          fernando padão
                                          arquiteto
