    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
      JEER
      Hello Anton!
      I have installed this plug-in and when started a SU , came a window:
      Error Loading File C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
      Error: #<Exception: An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons:
      • Encoding::CompatibilityError: incompatible character encodings: Windows-1250 and UTF-8
      C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
      C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
      C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
      My SU is 2016 64 bit (16.1.2104)
      My wsystem WIN10
        C:/Users/Jen**ő**/...
        Contains an accented character.
        The extension's coding was updated to fix the user-path encoding to UTF-8, so do you have the latest version installed ?
        If so then perhaps Anton needs to make his re-encoding more robust ?
        • K Offline
          khturnings
          Just installed Sketchup Make 2017 and tried to install MSPhysics 0.9.6 and AMS 3.4.0 and got this error ---
          Error Loading File C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/main.rb
          • LoadError: 126: The specified module could not be found. - C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/win64/2.2/msp_lib.so
          • LoadError: 126: The specified module could not be found. - C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/win64/2.2/msp_lib_no_sdl.so
          C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in load'
          C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
          C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
            Anton_S
            That's unfortunate. Looks like I will need to create another account to ensure that the encoding error is actually not fixed.
              M3one
              I'm want to do a path following object, but I don't really know how. I found on this thread that it's done with curvy joints, but I'm lost. Please, can you explain how or do you have kind of example?
              Thanks!
                Anton_S
                Okay, those loading and encoding issues should be fixed now. Upgrade to 0.9.7.
                  Anton_S
                  Hi M3one,
                  At the moment, you can refer to this tutorial on curvy joints.
                  https://www.youtube.com/watch?v=dU-KgxKc0ds
                  You can also check out this example model at 3Dwarehouse.
                  https://3dwarehouse.sketchup.com/model.html?id=d21984a9-477b-44d7-9eca-c191ae85afe4
                  Anton
                    M3one
                    @anton_s said:
                    Hi M3one,
                    Anton
                    Thanks Anton, I'll check it later
                    • K Offline
                      khturnings
                      Thanks Anton that has sorted the loading issue with Sketchup 2017.
                      Regards
                        Taner Batu
                        Hello, I can't download MSPhysics 0.9.7 plugin from your link!
                        • E Offline
                          Emersonvip
                          First of all thanks for sharing this great plugin
                          Please I need help. with chains.
                          • OxerO Offline
                            Oxer
                            I installed the last version 0.9.7 and it appears this message:
                            Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/main.rb
                            Error; #<Exception; An exception occurred while loading MSPhysics 0.9.7! The exception occurred due to one or more of the following reasons;
                            - LoadError; dlopen(/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                              Referenced from; /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                              Reason; image not found - /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib.bundle
                            - LoadError; MSPhysics library file, "/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib_no_sdl.bundle", is missing!
                            /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
                            /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
                            /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;90;in `register_extension'
                            /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;90;in `<module;MSPhysics>'
                            /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
                            SU2017 & OSX 10.11.6
                            http://www.oxervision.blogspot.com/
                              cristyan
                              Hello !!!
                              I think most stable version is MSPhysics_0.9.4 for now ... in MSPhysics_0.9.7 "Drag to orbit" does not work when the simulation is runing...
                              Emersonvip - you can browse through this forum about chains ( http://sketchucation.com/forums/search.php?keywords=chain%26amp;t=56852%26amp;sf=msgonly ). Here you have a file, see how it was done this chain piece by piece and you will understand how MSPhysics it works with chains.
                              as Anton wrote in a reply "You can adjust Update Timestep, Solver Model, and Update Rate for the desired speed, performance, and stability."
                              chain MSPhysics.skp
                                SketchyPhysicsNutt
                                Hi Anton and thanks for MSPhysics your done a great job so far congratulations.
                                only problem for me is new MS scripts are confusing....old sketcky user
                                waiting on more models with script examples in them.
                                Scaled down my j-pod/cable car model from Eneroth Railroad plugin
                                Curvy piston joint testing
                                http://s18.postimg.org/jnmuqm0x5/GIF2234.gif
                                thx again
                                • F Offline
                                  faust07
                                  The same here - Orbit doesn't work during simulation. Zooming in and out works.
                                  • P Offline
                                    PituPhysics
                                    Yes, For me also don't works the Middle click in 0.9.5+
                                      Anton_S
                                      Oxer, I fixed the loading issue on Mac OS X.
                                      Cristyan, Faust07, PituPhysics the orbiting issue should be fixed new.
                                      Please upgrade to 0.9.8.
                                      Thanks y'all for reporting!
                                      Anton
                                      • OxerO Offline
                                        Oxer
                                        Thanks!! 👍
                                        All works fine right now on Mac.
                                          Anton_S
                                          @oxer said:
                                          Thanks!! 👍
                                          Phew 😄
                                            DonDeEs
                                            Hi Anton
                                            Please, please could you help me.
                                            Firstly thanks for making it possible for us all to have this plugin. I really appreciate your work.
                                            I have one little problem which I am sure is easily remedied. In my models the groups or components are falling through each (like in the following post) a lot of the time.
                                            404 Not Found
                                            (sketchucation.com)
                                            I need to change a setting somewhere I guess but I have no idea which. I hope I haven't missed something obvious, I have tried looking for the solution online without success and I have tried systematically changing setting also without success.
                                            Many thanks once again.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 46
                                            • 47
                                            • 24 / 47
