    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      Anton_S
      Okay, those loading and encoding issues should be fixed now. Upgrade to 0.9.7.
        Anton_S
        Hi M3one,
        At the moment, you can refer to this tutorial on curvy joints.
        https://www.youtube.com/watch?v=dU-KgxKc0ds
        You can also check out this example model at 3Dwarehouse.
        https://3dwarehouse.sketchup.com/model.html?id=d21984a9-477b-44d7-9eca-c191ae85afe4
        Anton
          M3one
          @anton_s said:
          Hi M3one,
          Anton
          Thanks Anton, I'll check it later
          • K
            khturnings
            Thanks Anton that has sorted the loading issue with Sketchup 2017.
            Regards
            • T
              Taner Batu
              Hello, I can't download MSPhysics 0.9.7 plugin from your link!
              • E
                Emersonvip
                First of all thanks for sharing this great plugin
                Please I need help. with chains.
                • OxerO
                  Oxer
                  I installed the last version 0.9.7 and it appears this message:
                  Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/main.rb
                  Error; #<Exception; An exception occurred while loading MSPhysics 0.9.7! The exception occurred due to one or more of the following reasons;
                  - LoadError; dlopen(/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                    Referenced from; /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                    Reason; image not found - /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib.bundle
                  - LoadError; MSPhysics library file, "/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib_no_sdl.bundle", is missing!
                  /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
                  /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
                  /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;90;in `register_extension'
                  /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;90;in `<module;MSPhysics>'
                  /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
                  SU2017 & OSX 10.11.6
                  • C
                    cristyan
                    Hello !!!
                    I think most stable version is MSPhysics_0.9.4 for now ... in MSPhysics_0.9.7 "Drag to orbit" does not work when the simulation is runing...
                    Emersonvip - you can browse through this forum about chains ( http://sketchucation.com/forums/search.php?keywords=chain%26amp;t=56852%26amp;sf=msgonly ). Here you have a file, see how it was done this chain piece by piece and you will understand how MSPhysics it works with chains.
                    as Anton wrote in a reply "You can adjust Update Timestep, Solver Model, and Update Rate for the desired speed, performance, and stability."
                    chain MSPhysics.skp
                      SketchyPhysicsNutt
                      Hi Anton and thanks for MSPhysics your done a great job so far congratulations.
                      only problem for me is new MS scripts are confusing....old sketcky user
                      waiting on more models with script examples in them.
                      Scaled down my j-pod/cable car model from Eneroth Railroad plugin
                      Curvy piston joint testing
                      http://s18.postimg.org/jnmuqm0x5/GIF2234.gif
                      thx again
                      • F
                        faust07
                        The same here - Orbit doesn't work during simulation. Zooming in and out works.
                        • P
                          PituPhysics
                          Yes, For me also don't works the Middle click in 0.9.5+
                            Anton_S
                            Oxer, I fixed the loading issue on Mac OS X.
                            Cristyan, Faust07, PituPhysics the orbiting issue should be fixed new.
                            Please upgrade to 0.9.8.
                            Thanks y'all for reporting!
                            Anton
                            • OxerO
                              Oxer
                              Thanks!! πŸ‘
                              All works fine right now on Mac.
                                Anton_S
                                @oxer said:
                                Thanks!! πŸ‘
                                Phew πŸ˜„
                                  DonDeEs
                                  Hi Anton
                                  Please, please could you help me.
                                  Firstly thanks for making it possible for us all to have this plugin. I really appreciate your work.
                                  I have one little problem which I am sure is easily remedied. In my models the groups or components are falling through each (like in the following post) a lot of the time.
                                  404 Not Found
                                  (sketchucation.com)
                                  I need to change a setting somewhere I guess but I have no idea which. I hope I haven't missed something obvious, I have tried looking for the solution online without success and I have tried systematically changing setting also without success.
                                  Many thanks once again.
                                    DonDeEs
                                    Hi Anton
                                    Is there a way I can tidy up the collision wireframe for Compound from CD shapes in the UI. Both the rack and the pinion I have drawn are not getting a very good collision detection wireframe so the gears are jumping out of the rack.
                                    I have checked the geometry in the models and they appear to be sound so I am assuming this is related to the way the wireframe is generated/calculated.
                                    Thanks again for this great plug in.
                                      Anton_S
                                      Hi, DonDeEs,
                                      The Collision from CD shape is not reliable. Its ability to calculate proper collision is limited. What you can do is manually divide sub-geometry of the gear into convex-hull groups. Then assign Compound shape to the top level group. So, for the gear, every tooth should have its own group. The top level group, of Compound shape, should contain all the teeth.
                                      For the chains, using collision as the constraint for keeping the objects from falling apart is not a viable approach. Yes, increasing the density of all chain links can get all pieces to hold tight, but they will break once a certain amout of force is applied. What would be a better solution is having every peace of chain interconnected by a ball-and-socket joint. There is a very efficient way to do it. Here, check out this example:
                                      artificial_chains.skp
                                      I might create a YouTube tutorial for it later.
                                      Anton
                                        DonDeEs
                                        Hi Anton
                                        Many thanks for your reply. The solution makes sense. It will make modelling gears a little more complicated but that is ok. I guess I could also let the gears run as cylinders on a box collision shape for the rack (so they roll effectively) and null the gear teeth on both.
                                        I don't know if it helps you to know that when Collision Wireframe is enabled on the simulation it shows fine but if you use orbit the wireframes are lost. It means you effectively have to stop the simulation, orbit to where you want to see and restart in order to get the view you want with wireframe.
                                        It is a minor problem for me but maybe it is a bug that you are not aware of and can fix.
                                        Thanks again for your help.
                                          SketchyPhysicsNutt
                                          Hi Anton just reporting this little bug im getting with your ams windowsettingsv4.2.0
                                          plugin and MSphysics keeps jumping out of fullscreen.
                                          im using MSPhysics_0.9.8/Win 8.1/Sketchup 2016 and ae-toolbar editor plugin
                                          Before
                                          http://s3.postimg.org/divr36o8z/test1a.jpg
                                          After
                                          http://s18.postimg.org/np66r8oyh/test1b.jpg
                                          any info would help
                                          Tez
                                            DonDeEs
                                            Hi Anton
                                            That makes sense of the geared joints option. I had not really worked out what they were about but this is absolutely the solution I needed so many thanks.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 46
                                            • 47
                                            • 24 / 47
