    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • OxerO
      Oxer
      I obtain similar message:
      Error al cargar archivo /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
      Error; #<Exception; An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons;
      - LoadError; dlopen(/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
        Referenced from; /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
        Reason; image not found - /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
      - LoadError; MSPhysics library file, "/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
      /Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
      /Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
      /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in `register_extension'
      /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in `<module;MSPhysics>'
      /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
      OSX 10.11.6 SU2016
        Anton_S
        Alright, I'll look into this.
        • V
          vico44
          The 0.9.4 still working well on OS 10.11.6 SU2016
            JEER
            Hello Anton!
            I have installed this plug-in and when started a SU , came a window:
            Error Loading File C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
            Error: #<Exception: An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons:
            • Encoding::CompatibilityError: incompatible character encodings: Windows-1250 and UTF-8
            C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
            C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
            C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
            My SU is 2016 64 bit (16.1.2104)
            My wsystem WIN10
              C:/Users/Jen**ő**/...
              Contains an accented character.
              The extension's coding was updated to fix the user-path encoding to UTF-8, so do you have the latest version installed ?
              If so then perhaps Anton needs to make his re-encoding more robust ?
              • K
                khturnings
                Just installed Sketchup Make 2017 and tried to install MSPhysics 0.9.6 and AMS 3.4.0 and got this error ---
                Error Loading File C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/main.rb
                • LoadError: 126: The specified module could not be found. - C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/win64/2.2/msp_lib.so
                • LoadError: 126: The specified module could not be found. - C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/win64/2.2/msp_lib_no_sdl.so
                C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in load'
                C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
                C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
                  Anton_S
                  That's unfortunate. Looks like I will need to create another account to ensure that the encoding error is actually not fixed.
                    M3one
                    I'm want to do a path following object, but I don't really know how. I found on this thread that it's done with curvy joints, but I'm lost. Please, can you explain how or do you have kind of example?
                      Anton_S
                      Okay, those loading and encoding issues should be fixed now. Upgrade to 0.9.7.
                        Anton_S
                        Hi M3one,
                        At the moment, you can refer to this tutorial on curvy joints.
                        https://www.youtube.com/watch?v=dU-KgxKc0ds
                        You can also check out this example model at 3Dwarehouse.
                        https://3dwarehouse.sketchup.com/model.html?id=d21984a9-477b-44d7-9eca-c191ae85afe4
                        Anton
                          M3one
                          @anton_s said:
                          Hi M3one,
                          Anton
                          Thanks Anton, I'll check it later
                          • K
                            khturnings
                            Thanks Anton that has sorted the loading issue with Sketchup 2017.
                            Regards
                            • T
                              Taner Batu
                              Hello, I can't download MSPhysics 0.9.7 plugin from your link!
                              • E
                                Emersonvip
                                First of all thanks for sharing this great plugin
                                Please I need help. with chains.
                                • OxerO
                                  Oxer
                                  I installed the last version 0.9.7 and it appears this message:
                                  Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/main.rb
                                  Error; #<Exception; An exception occurred while loading MSPhysics 0.9.7! The exception occurred due to one or more of the following reasons;
                                  - LoadError; dlopen(/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib.bundle, 9); Library not loaded; @loader_path/../libSDL2-2.0.0.dylib
                                    Referenced from; /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
                                    Reason; image not found - /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib.bundle
                                  - LoadError; MSPhysics library file, "/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib_no_sdl.bundle", is missing!
                                  /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
                                  /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
                                  /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;90;in `register_extension'
                                  /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;90;in `<module;MSPhysics>'
                                  /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
                                  SU2017 & OSX 10.11.6
                                  • C
                                    cristyan
                                    Hello !!!
                                    I think most stable version is MSPhysics_0.9.4 for now ... in MSPhysics_0.9.7 "Drag to orbit" does not work when the simulation is runing...
                                    Emersonvip - you can browse through this forum about chains ( http://sketchucation.com/forums/search.php?keywords=chain%26amp;t=56852%26amp;sf=msgonly ). Here you have a file, see how it was done this chain piece by piece and you will understand how MSPhysics it works with chains.
                                    as Anton wrote in a reply "You can adjust Update Timestep, Solver Model, and Update Rate for the desired speed, performance, and stability."
                                    chain MSPhysics.skp
                                      SketchyPhysicsNutt
                                      Hi Anton and thanks for MSPhysics your done a great job so far congratulations.
                                      only problem for me is new MS scripts are confusing....old sketcky user
                                      waiting on more models with script examples in them.
                                      Scaled down my j-pod/cable car model from Eneroth Railroad plugin
                                      Curvy piston joint testing
                                      http://s18.postimg.org/jnmuqm0x5/GIF2234.gif
                                      thx again
                                      • F
                                        faust07
                                        The same here - Orbit doesn't work during simulation. Zooming in and out works.
                                        • P
                                          PituPhysics
                                          Yes, For me also don't works the Middle click in 0.9.5+
                                            Anton_S
                                            Oxer, I fixed the loading issue on Mac OS X.
                                            Cristyan, Faust07, PituPhysics the orbiting issue should be fixed new.
                                            Please upgrade to 0.9.8.
                                            Thanks y'all for reporting!
                                            Anton
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 46
                                            • 47
                                            • 24 / 47
