    MSPhysics 1.0.3 (16 October 2017)
    927 Posts 171 Posters 1.1m Views 172 Watching
    • tt_suT Offline
      tt_su
      @anton_s said:
      hack into my PC and steal the files.
      πŸ’­ πŸ‘Ώ
        Anton_S
        Hello guys,
        I posted the first alpha version. There are still a lot of things to be worked on, but I thought it wouldn't be a bad idea to upload updates as I go.
        Go to the first post and read all the compatibility and requirements, as this plugin is not user friendly yet.
        As far as uploading it to GitHub, it will be in a matter of days.
        I haven't yet created joints, and the dialog, but you can test destructing building and such things...
        Have a nice day!
        • cottyC Offline
          cotty
          Fist test VERY promising! πŸ‘ πŸŽ‰
          [screenr:1z6ajd7z]yhhN[/screenr:1z6ajd7z]
          my SketchUp gallery
          • K Offline
            kaas
            Very nice. First test no problems. Considering modelling a pachinko machine...
            • tt_suT Offline
              tt_su
              πŸŽ‰ 😍
                josuapa
                [screenr:zkq34ycx]yhhN[/screenr:zkq34ycx]
                It's awesome. I'm testing, but my blocks fall into infinity (the boundary surface drops as well) πŸ˜• . I do not know how to make a surface to retain them. How I can fix it? Could you stop the simulation and save the drawing? Thank you! πŸ˜„
                • cottyC Offline
                  cotty
                  You need a static mesh (context menu).
                  my SketchUp gallery
                    Anton_S
                    It states in the status text to use SHIFT key to lift objects.
                    You can use ESC to quit and Break/Pause button to toggle play.
                      josuapa
                      Thanks a lot ! It's perfect !!!! 😍
                      • PixeroP Offline
                        Pixero
                        Can it do soft bodies too?
                        • soloS Offline
                          solo
                          Can you explain this a little more detail?
                          Say I want to fill a bowl with marbles, how can that be done?
                          http://www.solos-art.com
                          • jiminy-billy-bobJ Offline
                            jiminy-billy-bob
                            Select your bowl, in the context menu choose "static" in "state", and "coumpound from mesh" in "shape".
                              Anton_S
                              Newton 3.12 has that feature, but its unfinished. I might integrate it into MSPhysics when its finished.
                                Anton_S
                                Compound from mesh bodies are not recommended, as complex bodies could generate improper collisions. You might set a bowl static mesh, but make sure that the front faces are always facing out because the front faces are the only faces that generate the collisions, not the back faces.
                                • tt_suT Offline
                                  tt_su
                                  Like tribles? πŸ˜„
                                  • PixeroP Offline
                                    Pixero
                                    @tt_su said:
                                    Like tribles? πŸ˜„
                                    You mean, like Trimbles? πŸ˜›
                                    No, I mean like flags, cloth and such.
                                    • K Offline
                                      kaas
                                      Tried a bowl like Solo suggested. Marbles are falling though the bowl. So tried some boxes. Had to scale everything x10 or the boxes would stick through the bowl. I guess I need to tweak some settings.
                                      msPhysics_bowl.skp
                                        Anton_S
                                        Yeah, tiny objects are no good for newton. Another thing is I'll add the continuous collision mode feature, where objects won't fly through at fast speeds.
                                        • O Offline
                                          otb designworks
                                          What are the chances of a mac version?
                                          Cheers, Chuck
                                          OTB Designworks is on Youtube
                                            Anton_S
                                            The chances of a Mac version is like the chances of snow here in Salem Oregon - 3% πŸ˜†
                                            As you noticed this plugin requires AMS Library which is fully dependent on the Windows API. The mac version will be created, but it will lack a lot of features from the Windows version.
                                            • 46
                                            • 47
                                            • 2 / 47
