    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • soloS
      @anton_s said:
      @solo said:
      This will be crazy awesome, please pick me if you need testers as I would love to play with this.
      I'll post a beta version someday.
      Someday?
        Anton_S
        @solo said:
        Someday?
        Maybe in a couple of months.
        • KrisidiousK
          Krisidious
          This is the internet... If there's no Beta, it didn't happen.
          By: Kristoff Rand
          • cottyC
            cotty
            @anton_s said:
            The aim of writing this plugin is to bring SketchyPhysics back!
            Great idea πŸ‘ ❗
            my SketchUp gallery
              Anton_S
              πŸ˜’ You know what? I don't care if you think it doesn't exist. πŸ˜† I'm good as long as you're not planning to hack into my PC and steal the files.
              • tt_suT
                tt_su
                πŸ’­ πŸ‘Ώ
                  Anton_S
                  Hello guys,
                  I posted the first alpha version. There are still a lot of things to be worked on, but I thought it wouldn't be a bad idea to upload updates as I go.
                  Go to the first post and read all the compatibility and requirements, as this plugin is not user friendly yet.
                  As far as uploading it to GitHub, it will be in a matter of days.
                  I haven't yet created joints, and the dialog, but you can test destructing building and such things...
                  Have a nice day!
                  • cottyC
                    cotty
                    Fist test VERY promising! πŸ‘ πŸŽ‰
                    [screenr:1z6ajd7z]yhhN[/screenr:1z6ajd7z]
                    my SketchUp gallery
                    • K
                      kaas
                      Very nice. First test no problems. Considering modelling a pachinko machine...
                      • tt_suT
                        tt_su
                        πŸŽ‰ 😍
                          josuapa
                          [screenr:zkq34ycx]yhhN[/screenr:zkq34ycx]
                          It's awesome. I'm testing, but my blocks fall into infinity (the boundary surface drops as well) πŸ˜• . I do not know how to make a surface to retain them. How I can fix it? Could you stop the simulation and save the drawing? Thank you! πŸ˜„
                          • cottyC
                            cotty
                            You need a static mesh (context menu).
                            my SketchUp gallery
                              Anton_S
                              It states in the status text to use SHIFT key to lift objects.
                              You can use ESC to quit and Break/Pause button to toggle play.
                                josuapa
                                Thanks a lot ! It's perfect !!!! 😍
                                • PixeroP
                                  Pixero
                                  Can it do soft bodies too?
                                  • soloS
                                    Can you explain this a little more detail?
                                    Say I want to fill a bowl with marbles, how can that be done?
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      Select your bowl, in the context menu choose "static" in "state", and "coumpound from mesh" in "shape".
                                        Anton_S
                                        Newton 3.12 has that feature, but its unfinished. I might integrate it into MSPhysics when its finished.
                                          Anton_S
                                          Compound from mesh bodies are not recommended, as complex bodies could generate improper collisions. You might set a bowl static mesh, but make sure that the front faces are always facing out because the front faces are the only faces that generate the collisions, not the back faces.
                                          • tt_suT
                                            tt_su
                                            Like tribles? πŸ˜„
