[Plugin] Find My Plugins Folder
With all the recent changes to the plugin folder location here is an addition to SketchUcation Tools that will allow you to open your plugins folder quickly....
http://sketchucation.com/pluginstore?pln=SCF-openPluginsFolder
I downloaded and installed but I do not see it in my plugins tab. I am using windows 7 professional.
Did you restart SU?
Same here. The file did get installed in my AppData/<...>/Plugins/SketchUcation folder, but doesn't appear in the menu.
Look under the the SketchUcation menu.
That's what I'm looking for but it is not listed in the plugins tab or anywhere else in the menus.
Have you installed the Plugin store itself?
If not you can download it from the link at the top of the page. -
Plugins > SketchUcation > Find My Plugins....
If not you can download it from the link at the top of the page.Ok, that worked. I didn't realize I needed that. Cool little tool BTW.
@jim said:
Which makes my problem even more weird.
sub-menu's will only update after a restart...
just cautiously reminding...
john -
Hehe, I've rebooted SketchUp hundreds of times just today - I have a Hotkey for it when writing plugins.
I just installed via the SCF Plugin and it's one folder deeper than you show...
EDIT... sorry I'm wrong, not use to the PC folder view...
Just looked at the loader code and can see the problem. Using a timer and trying to guess when your submenu will be ready is pretty fragile.
With your input, this post could be even better ๐
Register LoginAdvertisement
