    [Plugin] Find My Plugins Folder
    16 Posts 6 Posters 6.2k Views 6 Watching
      With all the recent changes to the plugin folder location here is an addition to SketchUcation Tools that will allow you to open your plugins folder quickly....
      404 Not Found
      (sketchucation.com)
        pomelo3d
        πŸ˜„
        • Mistro11M Offline
          Mistro11
          I downloaded and installed but I do not see it in my plugins tab. I am using windows 7 professional.
          i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
          Structural Integrity is Not Just Physical...It's in the Design and Purpose
          • BoxB Offline
            Did you restart SU?
              Jim
              Same here. The file did get installed in my AppData/<...>/Plugins/SketchUcation folder, but doesn't appear in the menu.
                Look under the the SketchUcation menu.
                • Mistro11M Offline
                  Mistro11
                  That's what I'm looking for but it is not listed in the plugins tab or anywhere else in the menus.
                  • BoxB Offline
                    Have you installed the Plugin store itself?
                    If not you can download it from the link at the top of the page.
                      Plugins > SketchUcation > Find My Plugins....
                        Jim
                        Yeah, it ain't there.
                        • Mistro11M Offline
                          Mistro11
                          Ok, that worked. I didn't realize I needed that. Cool little tool BTW.
                            Jim
                            Which makes my problem even more weird.
                              driven
                              sub-menu's will only update after a restart...
                              just cautiously reminding...
                                Jim
                                Hehe, I've rebooted SketchUp hundreds of times just today - I have a Hotkey for it when writing plugins.
                                  driven
                                  I just installed via the SCF Plugin and it's one folder deeper than you show...
                                  EDIT... sorry I'm wrong, not use to the PC folder view...
                                    Jim
                                    Just looked at the loader code and can see the problem. Using a timer and trying to guess when your submenu will be ready is pretty fragile.
