    SU 2014 and Plugins
    36 Posts 16 Posters 7.0k Views 16 Watching
    • sfto1S
      sfto1
      I have read the recommendation to use the Plugin Store to install "fresh" copies of extensions, which is ok, but what about the plugins from Smustard 😮
      Like the Make Faces plugin in particular
      How are the plugins that were simply dropped into a plugins folder installed now?
      I have an instant roof plugin from Vali Architects (that I purchased) that cannot be loaded at this time.
      Any ideas?
      • BoxB
        The plugin folder has been moved, the new location solves the security permissions issue.
        You'll find it at
        C:\Users\Username\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
        • J
          Jim
          You can still drop them in the Plugins folder, it's just that the Plugins folder has moved..
          Just try moving them one or a few at a time so when errors pop-up, you know which files caused the errors.
          On Vista, Win 7, 8:
          C;\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
          On Win XP:
          C;\Documents and Settings\<username>\Application Data\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
          On Windows, we also load plugins from a user-independent support directory.
          On Win Vista, 7, 8:
          C;\ProgramData\SketchUp\SketchUp 2014\SketchUp\Plugins
          On Win XP:
          C;\Documents and Settings\All Users\Application Data\SketchUp\SketchUp 2014\SketchUp\Plugins
          This path is only loaded to the $LOAD_PATH array if the folder exists when on the user's machine when SU starts.
            The point of downloading fresh copies is to make sure you get versions that are compatible with Ruby 2.0. If the plugins are on Smustard or some other host, you can download them and see what you get. They may have been updated or maybe not. Maybe they didn't need to be updated. At least you'll have the newest version of the plugin. If it doesn't work, maybe the author has some work to do but at least they can't come back and tell you that it's because you're using an obsolete version.
            • sfto1S
              sfto1
              Thanks All!
              • I
                ilay7k
                Plugins just for your use can must go in:
                >     %APPDATA%/SketchUp/SketchUp 2014/SketchUp/Plugins
                Plugins for use by all users of a PC can must go in:
                >     %PROGRAMDATA%/SketchUp/SketchUp 2014/SketchUp/Plugins
                Who makes such idea to use such paths ?
                You are fool. I did not install sketchup to root disk as "C:"(if PC/notebook has default installation). I tried to prevent user(friend, colleague) from crash of hard-disk, mainly it happens with C. And save numerous plug-ins, content
                Shit happens with dev team again 👎 What hell you are doing?
                • Bob JamesB
                  Bob James
                  Okay, so what/where should plugins go???.
                    Bob, see Jim's post above. If you're the only one using the plugins on your computer, use Appdata/Roaming... If you use the SCF Plugin Store or the Extension Warehouse, they'll go there automatically.
                    • soloS
                      solo
                      I must say using SU 2014 with minimal plugins is awesome, so fast to start and get stuff done, a great time to cull some hardly used plugins.
                      http://www.solos-art.com
                      • BoxB
                        So true Solo, and with the plugin store you can simply work away until you need a plugin and quickly auto install it.
                        • Bob JamesB
                          Bob James
                          Code: Select all
                          This is not
                          AppData**Roaming**\SketchUp\SketchUp 2014\SketchUp\Plugins
                          Or am I missing the obvious?
                            No. My error. Or Jim's. Here's a screen shot that might help.
                            • TIGT
                              To find your default Plugins folder, in the Ruby Console use:
                              Sketchup.find_support_file('Plugins')
                              It should return your personal 'User' Plugins folder... e.g.
                              C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                              • BoxB
                                Exactly as said in the first reply to the thread.
                                • TIGT
                                  But you quoted what it ought to be, rather than telling him how to find what it actually is set to be... 😒
                                  • D
                                    driven
                                    if your prepared to use 'Ruby Console'
                                    copy paste this
                                    UI.openpanel(Sketchup.find_support_file("Plugins"))
                                    then hit enter...
                                    @TIG, maybe SCF_ could have a 'Plugins folder' menu item???
                                    john
                                    • TIGT
                                      copy paste this
                                      then hit enter...
                                      john
                                      Good tip.
                                      Good idea... 😒
                                      • I
                                        ilay7k
                                        I work in another 3d app. App's developers made command-console's command which points where user can have own preferences dir with such dirs: _bugreports, library, plugins, prefs, tex, updates
                                        i prefer if we can select plugin-dir in preferences of sketchup or simply override it by command: sketchup.exe -userdir "X:\skippyDir"
                                        • cottyC
                                          cotty
                                          @ilay7k said:
                                          You can add folder with Fredos Additional Plugin Folders.
                                          my SketchUp gallery
                                          • I
                                            ilay7k
                                            Hi Carsten
                                            Thanks for info.
                                            BUT i want it will be by default and from true TSKU dev.team
                                            Ok?
                                            • 1 / 2
