    Board streaching
    20 Posts 7 Posters 1.5k Views 7 Watching
    • F Offline
      Futurepast
      Here's something to send out to the contractors of the world 😄
      http://www.finehomebuilding.com/item/22728/how-to-save-a-miscut-board-from-the-scrap-bin
      • jeff hammondJ Offline
        jeff hammond
        lol 👍
        "coming to an adult video store soon"
        dotdotdot
        • mitcorbM Offline
          mitcorb
          @Jeff:
          You know if you are still doing those skateboard courses, you might be able to use some of this goop. All you would need is a multidirectional stretcher rig. 💚
          Of course, I don't really think you would need to use the stuff. It is clear that you always take the care necessary to do the job correctly in the first place.
            jeff hammond
            @mitcorb said:
            @Jeff:
            yeah, there are times when being able to flex wood easier would be an advantage.. that said, the less goopy stuff on a job site, the better! 😉
            dotdotdot
            • arail1A Offline
              arail1
              I assume the date on that video is the point, right?
                jeff hammond
                sheesh.. i believed it!
                dotdotdot
                • F Offline
                  Futurepast
                  Don't feel bad Jeff, half the people I've shown this to also fell for it! He played it up real good in the vid. 😆
                    I remember when that first came out. He did do a great job on that.
                    • mitcorbM Offline
                      mitcorb
                      Measure once. Cut twice. Still too short. 💚
                        jeff hammond
                        well, i did pick up a good tip on the video which was shown after so being aprilFooled was worth it 😉
                        that being-- how to chalk this line (red) on a piece of 4x8 by yourself.. this little dilemma comes up pretty often on site.
                        dotdotdot
                        • mitcorbM Offline
                          mitcorb
                          Hi, Jeff:
                          Considering the amount of use and abuse your structures experience, how often are you called out to do repairs? Do you use a special grade of plywood? I realize the skate truck wheels are soft, but all of that dynamic stress must be significant?
                            Pilou, a chalkline is a string in a box full of chalk--commonly blue-- that is used for snapping a line. If the line is hooked on the side of the board as in Jeff's drawing, it is difficult to keep the hook from sliding inless someone holds it or you put a nail in the edge of the board.
                            http://www.forasia.cn/image-upload/20101027183154.jpg
                              With a chalk 😄
                              There is not an infinity number of possibilities ? 😲
                              What is unity of 4x8 - meters ?
                              So take another piece of 4x8 as rule ?
                                http://www.voilavie.fr/files/0/0/0/0/00005664.jpg
                                • mitcorbM Offline
                                  mitcorb
                                  Is that Kito Raup's pencil?
                                    So like this with the chalkline?
                                      That could work. Or you could tap a nail into the edge of the board maybe. It depends upon what you need to do.
                                      • BoxB Offline
                                        The tip that Jeff is referring to is to simply make a knife cut in the edge of the board to trap the string and hold it in place on the angle.
                                          Yeah. I figured maybe Pilou would actually watch it. 😉
                                            Don't know if they have a model with Chalkline? 😉
                                            http://design-produit.net/wp-content/uploads/2012/10/CouteauSuisseGuiness.jpg
