πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Board streaching
20 Posts 7 Posters 738 Views 7 Watching
  • F Offline
    Futurepast
    Here's something to send out to the contractors of the world πŸ˜„
    (www.finehomebuilding.com)
      lol πŸ‘
      "coming to an adult video store soon"
        mitcorb
        @Jeff:
        You know if you are still doing those skateboard courses, you might be able to use some of this goop. All you would need is a multidirectional stretcher rig. πŸ’š
        Of course, I don't really think you would need to use the stuff. It is clear that you always take the care necessary to do the job correctly in the first place.
          @mitcorb said:
          @Jeff:
          yeah, there are times when being able to flex wood easier would be an advantage.. that said, the less goopy stuff on a job site, the better! πŸ˜‰
          • topic:timeago-later,7 days
            arail1
            I assume the date on that video is the point, right?
              sheesh.. i believed it!
              • F Offline
                Futurepast
                Don't feel bad Jeff, half the people I've shown this to also fell for it! He played it up real good in the vid. πŸ˜†
                  I remember when that first came out. He did do a great job on that.
                    mitcorb
                    Measure once. Cut twice. Still too short. πŸ’š
                      well, i did pick up a good tip on the video which was shown after so being aprilFooled was worth it πŸ˜‰
                      that being-- how to chalk this line (red) on a piece of 4x8 by yourself.. this little dilemma comes up pretty often on site.
                        mitcorb
                        Hi, Jeff:
                        Considering the amount of use and abuse your structures experience, how often are you called out to do repairs? Do you use a special grade of plywood? I realize the skate truck wheels are soft, but all of that dynamic stress must be significant?
                          Pilou, a chalkline is a string in a box full of chalk--commonly blue-- that is used for snapping a line. If the line is hooked on the side of the board as in Jeff's drawing, it is difficult to keep the hook from sliding inless someone holds it or you put a nail in the edge of the board.
                          http://www.forasia.cn/image-upload/20101027183154.jpg
                            With a chalk πŸ˜„
                            There is not an infinity number of possibilities ? 😲
                            What is unity of 4x8 - meters ?
                            So take another piece of 4x8 as rule ?
                              πŸ˜„
                              http://www.voilavie.fr/files/0/0/0/0/00005664.jpg
                                mitcorb
                                Is that Kito Raup's pencil?
                                  So like this with the chalkline?
                                    That could work. Or you could tap a nail into the edge of the board maybe. It depends upon what you need to do.
                                      The tip that Jeff is referring to is to simply make a knife cut in the edge of the board to trap the string and hold it in place on the angle.
                                        Yeah. I figured maybe Pilou would actually watch it. πŸ˜‰
                                          Don't know if they have a model with Chalkline? πŸ˜‰
                                          http://design-produit.net/wp-content/uploads/2012/10/CouteauSuisseGuiness.jpg
