    Board streaching
    20 Posts 7 Posters 1.5k Views 7 Watching
    • mitcorbM Offline
      mitcorb
      @Jeff:
      You know if you are still doing those skateboard courses, you might be able to use some of this goop. All you would need is a multidirectional stretcher rig. 💚
      Of course, I don't really think you would need to use the stuff. It is clear that you always take the care necessary to do the job correctly in the first place.
      • jeff hammondJ Offline
        @mitcorb said:
        @Jeff:
        yeah, there are times when being able to flex wood easier would be an advantage.. that said, the less goopy stuff on a job site, the better! 😉
        • arail1A Offline
          arail1
          I assume the date on that video is the point, right?
            sheesh.. i believed it!
            • F Offline
              Futurepast
              Don't feel bad Jeff, half the people I've shown this to also fell for it! He played it up real good in the vid. 😆
                I remember when that first came out. He did do a great job on that.
                • mitcorbM Offline
                  mitcorb
                  Measure once. Cut twice. Still too short. 💚
                    well, i did pick up a good tip on the video which was shown after so being aprilFooled was worth it 😉
                    that being-- how to chalk this line (red) on a piece of 4x8 by yourself.. this little dilemma comes up pretty often on site.
                    • mitcorbM Offline
                      mitcorb
                      Hi, Jeff:
                      Considering the amount of use and abuse your structures experience, how often are you called out to do repairs? Do you use a special grade of plywood? I realize the skate truck wheels are soft, but all of that dynamic stress must be significant?
                        Pilou, a chalkline is a string in a box full of chalk--commonly blue-- that is used for snapping a line. If the line is hooked on the side of the board as in Jeff's drawing, it is difficult to keep the hook from sliding inless someone holds it or you put a nail in the edge of the board.
                        http://www.forasia.cn/image-upload/20101027183154.jpg
                          With a chalk 😄
                          There is not an infinity number of possibilities ? 😲
                          What is unity of 4x8 - meters ?
                          So take another piece of 4x8 as rule ?
                            http://www.voilavie.fr/files/0/0/0/0/00005664.jpg
                            • mitcorbM Offline
                              mitcorb
                              Is that Kito Raup's pencil?
                                So like this with the chalkline?
                                  That could work. Or you could tap a nail into the edge of the board maybe. It depends upon what you need to do.
                                  • BoxB Offline
                                    The tip that Jeff is referring to is to simply make a knife cut in the edge of the board to trap the string and hold it in place on the angle.
                                      Yeah. I figured maybe Pilou would actually watch it. 😉
                                        Don't know if they have a model with Chalkline? 😉
                                        http://design-produit.net/wp-content/uploads/2012/10/CouteauSuisseGuiness.jpg
