    Vray proxy.
    renderpluginsextensions
    8 Posts 5 Posters 724 Views 5 Watching
    • W Offline
      wdobry
      Hi Everyone!
      Is it normal that exporting vray proxy in Sketchup 2013 take a very long time? I have 12 000 faces model (which is grouped several times inside) and export to vray proxy takes about 20min (SU seems to be freezed for this time). Is there something wrong with my model or its just normal?
        andybot
        Yes, unfortunately this happens on occasion. There is a bug in the current release, and there will be a patch released soon to fix this (and a few other issues.) You could try the obj to proxy converter if you have the file in obj format.
          dkendig
          reading/writing sketchup geometry data can be rather slow, but we did find some optimizations for the patch that andybot mentioned πŸ˜„ If you're interested in testing a nightly build to see if it behaves better for you, we would like to hear some feedback. Just send me a PM.
          Devin Kendig
          Developer
          • W Offline
            wdobry
            Thank you very much for your support. Unfortunately I've just registerd here so I cant send you PM. If there is any other to try this nightly build I want it. : )
            • V Offline
              valerostudio
              It's definitely fixed in the nightly. I had this issue a few months ago and it was fixed right away by Devin and the Chaos crew. Large models take about 10-15 seconds now.
                dkendig
                you can send me an email if you'd like, devin.kendig@usa.chaosgroup.com
                Devin Kendig
                Developer
                  reymond
                  how can i find the ply2vrmesh tool?
                  Sketchup & Vray Trainer
                    dkendig
                    it's bundled with the installer should be in the start menu
                    Devin Kendig
                    Developer
