    [Plugin] SketchUcation Tools 2.6
    212 Posts 58 Posters 136.7k Views 58 Watching
    • P Offline
      pomelo3d
      yes.
      • kenK Offline
        ken
        I have two computers, a desktop at home and a laptop, which I use when I have to go to the office. So that now that I can see which plugins require updating on the desktop, I was wondering, is there a file I can copy from my desktop to my laptop, such that when I do a check on what plugins need updating on the laptop, the program would also show which plugins are missing on the laptop and need to be downloaded.
        This way I could keep the laptop in sync with the desktop.
        Thanks in advance. This program was much needed.
        Ken
        • G Offline
          Gábor
          Hi Ken,
          In the future releases we plan to implement such a feature you're looking for. Until then in the "My Downloads" list you can see those plugins what you've ever downloaded from the pluginstore on any computer. At the moment no feature to port the "My installs" but it is on our "To Do List".
            Yes 😄
            A future version might well have a new 'My Syncs' tab - where you will be able to see what plugins you have installed on your current computer/SketchUp-version, AND also those extra ones on other computers/SketchUp-versions [provided you have accessed the PluginStore at least once from these alternative computers/SketchUp-versions], and then it'll offer you the chance to AutoInstall the missing ones - either clicked individually or in bulk [like the 'Update all' button in 'My Updates']...
            We are [hopefully] anticipating your needs/desires, and much of the needed codes is already available.
            We just need to assemble it and beta test etc...
            However, please do make suggestions for enhancements - there's always going to be something we haven't thought of 😉
              ArCAD-UK
              This is a great addition to SU and it keeps getting better. Love the updating notification, just updated four plugins that I didn't realise had been modified!
              I hope I've not missed the memo; installation of plugins is so simple, is there an easy way to uninstall unwanted plugins?
                There's a Plugins > SketchUcation item 'SketchUcation Plugins Uninstaller..'
                That opens a dialog similar to the Plugins Manager.
                It lets you Uninstall selected Plugins - the rb/rbs/rb!/rbs! files are renamed with a final x - rbx.rbsx/rb!x/rbs!x
                They do not then appear in the 'Plugins Manager' or 'My Installs' lists.
                You can Reinstall any 'x' plugins using the same dialog too.
                If you want to permanently remove these Uninstalled files from your system you'll need to do it manually - open your Plugins folder, filter by the final 'x', select them and 'delete'.
                The associated subfolder [if any] is usually named after the plugin file itself and so it can therefore be removed manually too, at the same time; although leaving it in the Plugins folder does no harm...
                • goatboyG Offline
                  goatboy
                  I get these two...
                  Error - Start up.pdf
                  One at start up, the second when I click on the Plug ins manager button.
                  Error - Plug Ins Manager.pdf
                  Also: I use multiple monitors, and the new tool bars and menus show up frequently on one of the other screens...am I the only one?
                  • Bob JamesB Offline
                    Bob James
                    I had not realized this was available 😲 😳
                    Very handy. 👍
                    Seems like this should also be in SketchUcation Plugins Store in the "My Setup" 😎
                      @goatboy...
                      It's a Plugins folder limited Security permissions problem...
                      Please read this which explains how to fix it...
                      http://sketchucation.com/forums/viewtopic.php?p=508319#p508319
                      • BoxB Offline
                        Tig could you put that permissions business together as a sticky so you don't have to write it again and we can just link to it.
                          @Box
                          I keep meaning to...
                          I will ! 😕
                          [mod=:o474z5tl]I have !
                          ...[/mod:o474z5tl]
                          • jeff hammondJ Offline
                            jeff hammond
                            2 little UI(?) suggestions
                            • when logging in, the ability to press <return> once your name&password has been typed instead of needing to mouseclick on the login button
                            • some sort of feedback upon clicking 'autoinstall' that the plugin is actually downloading.. i.e.- a little spinning wheel pops up somewhere.. or something.. similar to downloading via a browser as each app has some sort of user feedback that a page is loading or a file is downloading.
                            dotdotdot
                              mptak
                              I'm not sure if this is the right place to post but here goes. First off as usual I am truly in awe of the great work of both the Trimble Team and all of the developers contributing at SUcation. Here's my quandary. Sketchup 2013-Make is installed on 2000 laptops at my kid's high school (why not Pro is another story). However, admin permissions are required when trying to add even the most basic of plugins/tools. Any suggestions/ideas if this Sketchucation Tools 2.5 can get around this bureaucratic virtual wall.
                                Added to ToDo list
                                some sort of feedback upon clicking 'autoinstall' that the plugin is actually downloading.. i.e.- a little spinning wheel pops up somewhere.. or something...
                                Added 'or something' to ToDo list
                                • BoxB Offline
                                  It says downloading % in the bottom left corner on mine.
                                    Jeff means that the PluginStore Dialog box show a loading graphic when you click autoinstall not the status bar in SketchUp.
                                    In sme instance the download can be so fast that the need for a spinner would be pointless. But I do know on some plugin the few secs to mins needs to be indicated.
                                      jeff hammond
                                      oh.. then i change my suggestion.. make that ↑ work on mac.
                                      it's not a big deal for the tiny .rb files as the 'auto-installed' dialog pops up quickly.. with the larger sized plugins though and no feedback, there's enough time in between clicking the install button and the installed message for doubt to kick in on whether or not i clicked the button properly
                                      [EDIT]
                                      yes, exactly 👍
                                      dotdotdot
                                        @Jeff
                                        You can see in the My Setup bulk updater we display 'Loading' when you are installing multiple updates.
                                        In the next release we will expand this to all installs so there is visual indicators of 'sumthin' happening.
                                        You going to Basecamp Jeff?
                                          jeff hammond
                                          i haven't planned on it.. i'm going to make it one of these years mainly so i can have a few drinks with you all
                                          dotdotdot
                                          • P Offline
                                            pgarmyn
                                            It would be great to extend this plugin with jiminy-billy-bob's statistcs, to have statistics on all plugins
                                            http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=56056%26amp;p=508939#p508939
                                            • 10
                                            • 11
                                            • 2 / 11
