    How to render lines ?
    renderpluginsextensions
    10 Posts 5 Posters 5.5k Views 5 Watching
    • rishikeshavateR Offline
      rishikeshavate
      Hi friends,
      I have did a line art for a gate design. now i want to render it.
      As it it complex in design i don't want to use "Follow Me" or "Extrude along path" tools.
      Is there any other way, so that i can render the edges?
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Nope, you need geometry.
        Vray has VrayEdgesTex built in, but it has not been made available on Sketchup yet. It's a shame, 'cause it would be darn usefull!
          rishikeshavate
          thanx jiminy.
          follow me and extrude along edge takes lot of time.
          Also when two or more edges come at a point its difficult or tedious to make a geometry.
          Do u know any plugin for it?
          • BoxB Offline
            It's hard to say without seeing your drawing but you might find Tig's Extrude Edges by Vector will give you something to work with. You can select all the edges and pull them forward just a bit which should give you renderable geometry.
              rishikeshavate
              hi
              m attaching the line drawing (not much complex). It is on temple's gate.
              I want to extrude 3 mm circle on this. I can do it in small small parts. but the joints r not matching.
              Any help?
              • BoxB Offline
                There are several plugins that will convert edges. One would be Didier Bur's Lines2Tubes.
                http://sketchucation.com/forums/viewtopic.php?p=88592#p88592
                Another would be Pipe along Path.
                3mm is very small, scale up before you try to do it and back down again when done, otherwise the faces may not form.
                  rishikeshavate
                  Hi Box,
                  Thanx for ur reply. I think it will help me.
                  I will try it.
                  • ToboboT Offline
                    Tobobo
                    @rishikeshavate said:
                    Hi friends,
                    in Vray there is a type of material called 'toon' it allows you to render lines.
                    Toby
                    Philippians 4:13
                    • V Offline
                      valerostudio
                      It's not too complex. I would use TIG's tools or Pipe Along Path. 1001 bit Pro and Profile Builder can do this also.
                        rishikeshavate
                        Hi Box,
                        I will try it.
                        Hi box
                        I tried it and it helped me alot. It is easy to.
                        thanx for ur suggestions.
