    3d Animals
    Scheduled Pinned Locked Moved Organic Modelling
    17 Posts 7 Posters 11.9k Views 7 Watching
      Sartje
      hello
      i want to know how to make 3d Animals.
      but i can't figure it out 😒
      i have already made something but i don't know if im doing it good.
      and i don't know how to add it here to show it ❓
      i hope someone can help me πŸ˜„
      • massimoM Offline
        massimo Moderator
        Hi, use the upload attachment feature which you can see at the bottom of the posting panel.
        Click the "upload attachment" label-->browse the file-->add the file.
        Once loaded the file you can also place it inline by pressing the "place inline" button.
          With Artisan or Subdivide an Smooth both by Dale Martens
          Girafe By Solo
          http://sketchucation.com/forums/download/file.php?id=63754&t=1
          http://sketchucation.com/forums/download/file.php?id=63755&t=1
            Sartje
            i hope this is the good file
            Leeuw.skp
              Sartje
              Girafe By Solo
              woow 😲 this is what i want to but i can't finf a tutorial
              to do this
              • olisheaO Offline
                olishea
                The image is the tutorial πŸ˜‰
                oli
                  Image is the tutorial πŸ˜‰
                  Yes! πŸ€“
                  Import an Image as model
                  Make a close surface (for the half model)
                  Divide it by lines
                  Make some extrude volumes and faces
                  Refine them
                  Apply subdivison with one of the 2 plugins above
                  That's all πŸ˜‰
                  Another one by Nomeradona 😎
                  http://i334.photobucket.com/albums/m421/nomeradona_1234/Ignacio/3.jpg
                  Now you can make a complet zoo! πŸ˜‰
                    Sartje
                    πŸ˜„
                      Sartje
                      Yes! πŸ€“
                      Divide it by lines
                      Refine them
                      That's all πŸ˜‰
                      thank you i will try it πŸ˜›
                      • BoxB Offline
                        It might be worth pointing out that you have saved your file looking at your lion from underneath. It is lying on it's side and under the ground plane.
                        Getting the orientation right makes life easier.
                        With the origin point at bottom left of the screen, Solid blue line goes up, solid red to the right and solid green into the distance.
                        This is the position you view from if you go Camera/standard views/Front.
                          Sartje
                          thanks for the info
                          but how do i get it to stand up then?
                          • pbacotP Offline
                            thanks for the info
                            Use the rotate tool to rotate it into position. Move it up if needed--above ground plane.
                            • BoxB Offline
                              Select all of it and use the rotate tool.
                              Or make it a group or component and you can easily move it about and rotate it etc.
                              [screenr:2ymubpls]am9H[/screenr:2ymubpls]
                                Sartje
                                [screenr:w3zkzdz5]am9H[/screenr:w3zkzdz5]
                                thankss πŸ˜„
                                  Sartje
                                  i have followed the steps only when i want to use the Move tool to make layers
                                  it wont work?
                                  its not going forward but it goes right or left πŸ˜•
                                  Leeuw 3.skp
                                  • soloS Offline
                                    solo
                                    @sartje said:
                                    thanks for the info
                                    The question is how are your SU skills? If you do not know how to move and align a model yet maybe creating animals is premature with your current SU proficiency.
                                    At moment I'm swamped with work, maybe some time in the future I will do a tutorial video on how to create animals.
                                    http://www.solos-art.com
                                      Sartje
                                      @solo said:
                                      @sartje said:
                                      thanks for the info
                                      I am a beginner yes but know already alot about sketchup and have made different things
                                      but never had to use the rotate to get something stand up so that's why i didn't know it.
