    3d Animals
    Scheduled Pinned Locked Moved Organic Modelling
    17 Posts 7 Posters 12.1k Views 7 Watching
      Sartje
      With Artisan or Subdivide an Smooth both by Dale Martens
      Girafe By Solo
      http://sketchucation.com/forums/download/file.php?id=63754&t=1
      http://sketchucation.com/forums/download/file.php?id=63755&t=1
      woow 😲 this is what i want to but i can't finf a tutorial
      to do this
      • olisheaO
        olishea
        The image is the tutorial πŸ˜‰
        oli
          Image is the tutorial πŸ˜‰
          Yes! πŸ€“
          Import an Image as model
          Make a close surface (for the half model)
          Divide it by lines
          Make some extrude volumes and faces
          Refine them
          Apply subdivison with one of the 2 plugins above
          That's all πŸ˜‰
          Another one by Nomeradona 😎
          http://i334.photobucket.com/albums/m421/nomeradona_1234/Ignacio/3.jpg
          Now you can make a complet zoo! πŸ˜‰
            Sartje
            πŸ˜„
              Sartje
              Yes! πŸ€“
              Divide it by lines
              Refine them
              That's all πŸ˜‰
              thank you i will try it πŸ˜›
              • BoxB
                It might be worth pointing out that you have saved your file looking at your lion from underneath. It is lying on it's side and under the ground plane.
                Getting the orientation right makes life easier.
                With the origin point at bottom left of the screen, Solid blue line goes up, solid red to the right and solid green into the distance.
                This is the position you view from if you go Camera/standard views/Front.
                  Sartje
                  thanks for the info
                  but how do i get it to stand up then?
                  • pbacotP
                    thanks for the info
                    Use the rotate tool to rotate it into position. Move it up if needed--above ground plane.
                    • BoxB
                      Select all of it and use the rotate tool.
                      Or make it a group or component and you can easily move it about and rotate it etc.
                      [screenr:2ymubpls]am9H[/screenr:2ymubpls]
                        Sartje
                        [screenr:w3zkzdz5]am9H[/screenr:w3zkzdz5]
                        thankss πŸ˜„
                          Sartje
                          i have followed the steps only when i want to use the Move tool to make layers
                          it wont work?
                          its not going forward but it goes right or left πŸ˜•
                          Leeuw 3.skp
                          • soloS
                            @sartje said:
                            thanks for the info
                            The question is how are your SU skills? If you do not know how to move and align a model yet maybe creating animals is premature with your current SU proficiency.
                            At moment I'm swamped with work, maybe some time in the future I will do a tutorial video on how to create animals.
                              Sartje
                              @solo said:
                              @sartje said:
                              thanks for the info
                              I am a beginner yes but know already alot about sketchup and have made different things
                              but never had to use the rotate to get something stand up so that's why i didn't know it.
