    3d Animals
    Scheduled Pinned Locked Moved Organic Modelling
    17 Posts 7 Posters 11.9k Views 7 Watching
    • olisheaO Offline
      olishea
      The image is the tutorial πŸ˜‰
      oli
        Image is the tutorial πŸ˜‰
        Yes! πŸ€“
        Import an Image as model
        Make a close surface (for the half model)
        Divide it by lines
        Make some extrude volumes and faces
        Refine them
        Apply subdivison with one of the 2 plugins above
        That's all πŸ˜‰
        Another one by Nomeradona 😎
        http://i334.photobucket.com/albums/m421/nomeradona_1234/Ignacio/3.jpg
        Now you can make a complet zoo! πŸ˜‰
          Sartje
          πŸ˜„
            Sartje
            Yes! πŸ€“
            Divide it by lines
            Refine them
            That's all πŸ˜‰
            thank you i will try it πŸ˜›
            • BoxB Offline
              It might be worth pointing out that you have saved your file looking at your lion from underneath. It is lying on it's side and under the ground plane.
              Getting the orientation right makes life easier.
              With the origin point at bottom left of the screen, Solid blue line goes up, solid red to the right and solid green into the distance.
              This is the position you view from if you go Camera/standard views/Front.
                Sartje
                thanks for the info
                but how do i get it to stand up then?
                • pbacotP Offline
                  thanks for the info
                  Use the rotate tool to rotate it into position. Move it up if needed--above ground plane.
                  • BoxB Offline
                    Select all of it and use the rotate tool.
                    Or make it a group or component and you can easily move it about and rotate it etc.
                    [screenr:2ymubpls]am9H[/screenr:2ymubpls]
                      Sartje
                      [screenr:w3zkzdz5]am9H[/screenr:w3zkzdz5]
                      thankss πŸ˜„
                        Sartje
                        i have followed the steps only when i want to use the Move tool to make layers
                        it wont work?
                        its not going forward but it goes right or left πŸ˜•
                        Leeuw 3.skp
                        • soloS Offline
                          @sartje said:
                          thanks for the info
                          The question is how are your SU skills? If you do not know how to move and align a model yet maybe creating animals is premature with your current SU proficiency.
                          At moment I'm swamped with work, maybe some time in the future I will do a tutorial video on how to create animals.
                            Sartje
                            @solo said:
                            @sartje said:
                            thanks for the info
                            I am a beginner yes but know already alot about sketchup and have made different things
                            but never had to use the rotate to get something stand up so that's why i didn't know it.
