    How can change the light intensity of spot light??
    renderpluginsextensions
    9 Posts 4 Posters 900 Views 4 Watching
      sketchuh
      i don't want the sport light to be too bright. i liked the fallof and light effect on the wall, but i don't like the light spilled on the floor. how can i change the light intensity? thanks.
      what units(scalar,lumens,...) should i use?
      i tried intensity 1000 on scalar unit.and used inverse square decay. only very faint light.
        sketchuh
        linear decay,
        linear decay
          rspierenburg
          Inverse square will give you a more realistic light falloff. The trick is that the intesity needs to be closer to the 10,000-20,000 level.
          • andybotA Offline
            andybot
            Indeed, you'll have to increase the intensity a lot if your scene also includes direct sunlight. Once you go to an interior scene and reduce the amount of sunlight, you will find you need lower values for your light intensity.
            • V Offline
              valerostudio
              My recommendation is to get a nice IES file.
              • andybotA Offline
                andybot
                ^^ which will disappear in sunlight 😞
                  sketchuh
                  ya...i agree..i just tested it out using very high setting 10000-20000...seemed to work. maybe i will get a nice ies light later.
                  • V Offline
                    valerostudio
                    HUH?
                    • andybotA Offline
                      andybot
                      hehe, I'm just thinking back to numerous posts "why doesn't my ies light show up" because they got some very low power ies file that won't work without 1m intensity. Just saying - OP needs to figure out the basics of artificial lighting in a scene before venturing down the ies maze...
