    Floor plan lines not connecting
    13 Posts 7 Posters 940 Views 7 Watching
    • J
      jasemilly
      I have followed a jpeg image of floor plan and the shape won't close so I can't pull the walls up. It's quite a complex floor plan, whats the best method for finding where the faults lie??
      thanks
      Jasemilly
      • M
        mwm5053
        Use styles, edit your style include endpoints and color by axis so you make sure you don't have stray lines. This a shot from a Mac but Win is simular.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • cottyC
          cotty
          One way would be to close parts and see where this fails. Or if there are small gaps, you can try the contour tool from architect tools to close them...
          Can you share a picture from the model (or the model itself)?
          my SketchUp gallery
          • cottyC
            cotty
            Or close gaps from edge tools?
            my SketchUp gallery
            • TIGT
              Check your units settings have no snaps set - otherwise you may snap short of a vertex.
              Also over-draw using rectangles - these will always face and can overlap.
              Delete the parts you don't need and pushpull the remaining faces...
              This is easier that trying to draw individual lines that form a face...
              • wind-borneW
                wind-borne
                thanks
                Jasemilly
                Stray Lines for diverse displays of faults.
                "To read between the lines was easier than to follow the text."OSX 10.11.6
                %(#BF80BF)[SU 8 pro
                • J
                  jasemilly
                  Used the stray lines plugin and it found one which I connected install and use very easy, thanks!!!
                  but it still won't pull up. I cant see what's wrong. Hoping someone could point out what I have done wrong.
                  tibthorpe.skp
                  • cottyC
                    cotty
                    Some welding, redraw one line, an intersection and some cleanup later...
                    tibthorpe1.skp
                    my SketchUp gallery
                    • S ShepherdS
                      S Shepherd
                      tibthorpe ss.skpI've fixed a few of these things by making a block around the plan, completely encasing all geometry. Select all, intersect with selection and delete the unwanted.
                      • J
                        jasemilly
                        Thanks!!!! what line needed to be redrawn and how to intersection help? How did you figure where the problems where the stray lines plugin only showed one.
                        thanks again jasemilly
                        • J
                          jasemilly
                          Thanks, much appreciated how does this work??? I am trying with this but so much I just don't know
                          jasemilly
                          • pbacotP
                            What I do is draw a rectangle in the plane of the imported edges. Maybe that is what is meant by "block". It sometimes helps parts of the model develop a face.
                            • S ShepherdS
                              S Shepherd
                              This is strange. I was going to put together a model showing how I intersected the plan. I started by drawing a box around the plan as drawn(2d). I then move/copied the the plan/rectangle and intersected all faces. Surprise, it was fixed. This does not work on the original.
                              In my previous post I was referring to 3d block pulled up and down from the 2d rectangle. I selected all and intersected selected. This worked on the original plan but isn't required on the copy. I have no idea why, other than it may close some ends with vertical errors.
                              I'd be happy to learn something here myself if anyone knows what's going on.
                              Slightly confused
                              SS
