    How to color a cartoon model
    20 Posts 7 Posters 1.6k Views 7 Watching
    • M
      mykrit
      I've been using sketchup for quite awhile mostly on interior and square objects which I have no problem painting on different faces, but once I decide to get to organic model I have no idea how to color face, eye, ear. etc. in separate colors since it made up on one object
      http://media-cache-ec0.pinimg.com/736x/fc/63/6b/fc636bdf07174bb2f25a741866f7f2aa.jpg
      I would normally make them separate object so I can color them as group but this is my first attempt on one piece and now I have a problem painting it. This could be a very dumb question but please any help..
        Select the faces you want to color and apply the desired color. Generally you should be applying materials to faces not groups or components.
        • M
          mykrit
          Thanks for prompt reply...
          I know that we paint on the face but in this case should I get on hidden geometry and pick each segment one by one....? That would take forever. I've attached the file please check
          mickey-wire.skp
          • M
            mykrit
            Sorry I should have titled the subject : How to apply multiple colors on one an organic shape.
              Pre-select the faces you want to apply the color to and paint them en masse. If you leave hidden geometry turned off you can paint entire surfaces rather than just the individual faces. Unhide or Unsoften edges that form boundaries between colors. If you want, you can hide or soften those edges after painting.
              • gillesG
                gilles
                In your case it would be easier to re draw the contour of faces you want to paint , hope you get some time.
                  No. Just create hard lines for the borders between colors. Those lines will limit the area of the color. Why don't you try it and see how you get on?
                  • M
                    mykrit
                    Do you mean I have to separate the face object by making one piece for head and another for face?
                    BTW how can I make a contour line over the face in this organic shape?
                    • T
                      TECHDAVE02
                      take a look at
                      http://www.youtube.com/watch?v=l2QjLlUQVrY
                      http://sketchucation.com/forums/viewtopic.php?f=323&t=44552#p397448
                        Dave, the issue is much more basic than that.
                        • M
                          mykrit
                          Thanks guy! I didn't know before that line can be draw over curve surface... once line limits the area thing is much easier...many thanks
                          • T
                            TECHDAVE02
                            Thanks I do tend to overthink things you are still the master
                              @techdave02 said:
                              ...you are still the master
                              Actually not so much but thank you.
                              • BoxB
                                I'm assuming you used Artisan to make your model, if so, it has a paint brush tool that allows you to freehand paint .
                                • soloS
                                  solo
                                  As Box said, if you did model it in SU I assume you used Artisan, then use the brush tool for painting, increase and decrease brush size with arrow keys as needed.
                                  I did a Mickey a while back and used this process too.
                                  http://www.solos-art.com
                                  • M
                                    mykrit
                                    Thank guy for the reply. BTW I only use basic SU tool and SDS only...not artisan so that I don't have the genius paint tool
                                    Re. SOLO yeah I saw your works and that inspires me so much that I create this... I learn your tricks of using proxy but unfortunately there's limitation on painting organic surface.
                                    • pbacotP
                                      Nice work modeling!
                                      • M
                                        mykrit
                                        @pbacot said:
                                        Nice work modeling!
                                        Thanks taken as compliment. Moving on to ironman's helmet
                                        • gillesG
                                          gilles
                                          You may find some interest with this:
                                          http://pixologic.com/sculptris/
                                          And it's free!
                                          • M
                                            mykrit
                                            And it's free!
                                            Exactly, but before I move on Sculptris I need to get a wacom first. πŸ‘
