    How to color a cartoon model
    20 Posts 7 Posters 1.6k Views 7 Watching
      No. Just create hard lines for the borders between colors. Those lines will limit the area of the color. Why don't you try it and see how you get on?
        mykrit
        @gilles said:
        In your case it would be easier to re draw the contour of faces you want to paint , hope you get some time.
        Do you mean I have to separate the face object by making one piece for head and another for face?
        BTW how can I make a contour line over the face in this organic shape?
        • T
          TECHDAVE02
          take a look at
          http://www.youtube.com/watch?v=l2QjLlUQVrY
          http://sketchucation.com/forums/viewtopic.php?f=323&t=44552#p397448
            Dave, the issue is much more basic than that.
              mykrit
              Thanks guy! I didn't know before that line can be draw over curve surface... once line limits the area thing is much easier...many thanks
              • T
                TECHDAVE02
                Thanks I do tend to overthink things you are still the master
                  @techdave02 said:
                  ...you are still the master
                  Actually not so much but thank you.
                  • BoxB
                    I'm assuming you used Artisan to make your model, if so, it has a paint brush tool that allows you to freehand paint .
                    • soloS
                      As Box said, if you did model it in SU I assume you used Artisan, then use the brush tool for painting, increase and decrease brush size with arrow keys as needed.
                      I did a Mickey a while back and used this process too.
                        mykrit
                        Thank guy for the reply. BTW I only use basic SU tool and SDS only...not artisan so that I don't have the genius paint tool
                        Re. SOLO yeah I saw your works and that inspires me so much that I create this... I learn your tricks of using proxy but unfortunately there's limitation on painting organic surface.
                        • pbacotP
                          Nice work modeling!
                            mykrit
                            @pbacot said:
                            Nice work modeling!
                            Thanks taken as compliment. Moving on to ironman's helmet
                            • gillesG
                              gilles
                              You may find some interest with this:
                              http://pixologic.com/sculptris/
                              And it's free!
                                mykrit
                                And it's free!
                                Exactly, but before I move on Sculptris I need to get a wacom first. πŸ‘
