    How to color a cartoon model
    20 Posts 7 Posters 1.6k Views 7 Watching
      Dave, the issue is much more basic than that.
        mykrit
        Thanks guy! I didn't know before that line can be draw over curve surface... once line limits the area thing is much easier...many thanks
        • T
          TECHDAVE02
          Thanks I do tend to overthink things you are still the master
            @techdave02 said:
            ...you are still the master
            Actually not so much but thank you.
            • BoxB
              I'm assuming you used Artisan to make your model, if so, it has a paint brush tool that allows you to freehand paint .
              • soloS
                As Box said, if you did model it in SU I assume you used Artisan, then use the brush tool for painting, increase and decrease brush size with arrow keys as needed.
                I did a Mickey a while back and used this process too.
                  mykrit
                  Thank guy for the reply. BTW I only use basic SU tool and SDS only...not artisan so that I don't have the genius paint tool
                  Re. SOLO yeah I saw your works and that inspires me so much that I create this... I learn your tricks of using proxy but unfortunately there's limitation on painting organic surface.
                  • pbacotP
                    Nice work modeling!
                      mykrit
                      @pbacot said:
                      Nice work modeling!
                      Thanks taken as compliment. Moving on to ironman's helmet
                      • gillesG
                        gilles
                        You may find some interest with this:
                        http://pixologic.com/sculptris/
                        And it's free!
                          mykrit
                          And it's free!
                          Exactly, but before I move on Sculptris I need to get a wacom first. πŸ‘
