    How to color a cartoon model
    20 Posts 7 Posters 1.2k Views 7 Watching
      mykrit
      Thanks guy! I didn't know before that line can be draw over curve surface... once line limits the area thing is much easier...many thanks
        TECHDAVE02
        Dave R. wrote
        Dave, the issue is much more basic than that.
        Thanks I do tend to overthink things you are still the master
          @techdave02 said:
          ...you are still the master
          Actually not so much but thank you.
          • BoxB Offline
            I'm assuming you used Artisan to make your model, if so, it has a paint brush tool that allows you to freehand paint .
            • soloS Offline
              As Box said, if you did model it in SU I assume you used Artisan, then use the brush tool for painting, increase and decrease brush size with arrow keys as needed.
              I did a Mickey a while back and used this process too.
                mykrit
                Thank guy for the reply. BTW I only use basic SU tool and SDS only...not artisan so that I don't have the genius paint tool
                Re. SOLO yeah I saw your works and that inspires me so much that I create this... I learn your tricks of using proxy but unfortunately there's limitation on painting organic surface.
                • pbacotP Offline
                  Nice work modeling!
                    mykrit
                    @pbacot said:
                    Nice work modeling!
                    Thanks taken as compliment. Moving on to ironman's helmet
                    • gillesG Offline
                      gilles
                      You may find some interest with this:
                      http://pixologic.com/sculptris/
                      And it's free!
                        mykrit
                        And it's free!
                        Exactly, but before I move on Sculptris I need to get a wacom first. πŸ‘
