    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 949.5k Views 155 Watching
    • Y
      yahyamsy
      Hi, I am just one guy, i don't need 3-seat license. is there a way to get JPP cheaper for one seat only Plz?!!
      thanks
        Rich O Brien Moderator @yahyamsy
        @yahyamsy it is 1 license that has 3 seats/activations to allow a license holder use it on multiple devices.
        • M
          Medness @hoverteamph
          @hoverteamph did they help you? How do you free up spaces that are unselected for deletion?
            Rich O Brien Moderator @Medness
            @Medness Update Sketchucation Tools to latest version: https://sketchucation.com/plugin/696-sketchucationtools on all devices to enable online releasing
            If you run into issues email us at support[at]sketchucation.com
            • A
              aleman_1940 Newcomers
              I have an error with the JointPushPull pluggin, every time i try the "J" Jointpushpull tool appears this error, i have the libfredo6-v16.a and the JointPushPull-v4.8a
              I Just wanted to make thicker a simple rectangle, i know i can use the other tools, but why do this error keeps appearing me
              What can i do?
              fredo6F 1 Reply Last reply
              • fredo6F
                fredo6 @aleman_1940
                @aleman_1940
                I would need to get the model where it is faulty.
                Possibly, you may work on tiny faces....
                • J
                  jskwonb
                  This post is deleted!
                  TIGT 1 Reply Last reply
                  • TIGT
                    TIG Moderator @jskwonb
                    @jskwonb
                    Have you tried following the advice in the error-message ?
                    Have you installed the latest versions of the extension, LibFredo6 and the SketchUcation tools [for the licensing], and restarted Sketchup to sync every thing ?
                    Also, this kind of error relating to reading a license file often occurs if your computer has not been named following Microsoft's conventions - e.g. its name should contain only ASCII letters and numbers, and a few other common punctuation characters; it should not contain special characters [I note your image's name contains some Asian characters]. You could try renaming your computer ?? Also your PC's user-name has similar restrictions...
                    • W
                      wkearney99 @whddnjs8474
                      Does 4.8a support doing vector pulls to a plane using SU2017?
                      I'm not seeing the added elements on the toolbar for it.
                      • fredo6F
                        fredo6 @wkearney99
                        @wkearney99
                        Do you mean the option in the Misc section?
                        Normally, there is no difference between Sketchup versions.
                        W 1 Reply Last reply
                        • W
                          wkearney99 @fredo6
                          @fredo6 yes, those, I don't see contours and the rest.
                          do they only appear when you're manipulating a certain kind of shapes or something?
                          I created a shape, selected some faces, selected the V tool
                          I ask this because I'm using the trial version and wanted to make sure I wasn't going to purchase something that wasn't going to work. I'm only using SU for 3D printing hobby stuff. I don't mind spending a few bucks to get decent software. I just wanted to make sure it'd work with what I've got.
                          - Sketchup: 17.2.2555
                          - LibFredo6: v14.9a
                          - LibFredo6 Binary loaded
                          - Sketchucation ExtensionStore: 4.4.1
                          - SCFLicense: v6.4a - 74
                          - Fredo6 Plugins
                              > FredoCorner v2.7a
                              > JointPushPull v4.8a
                              > RoundCorner v3.4a
                          - SCFLicense directory present
                              > Signature File: absent
                          Forgive me if I'm not doing something right. I saw the plugin on some videos and have tried to follow their steps and got stymied at not seeing the contour and other buttons.
                          My use-case for this is I've got a surface mesh from an STL that I want to extrude to a flat plane behind it.
                          • W
                            wkearney99 @wkearney99
                            @wkearney99 oh wait, I'm a dope, I didn't know about this button: 9dcfdde9-fc59-4b7b-a672-35ca04849d7e-image.png
                            Which gives me:
                            so, yeah, nevermind...
                            • fredo6F
                              fredo6 @wkearney99
                              @wkearney99
                              Yes, all buttons palettes in JPP have a compact mode, because some users said there was too many options....!
                              • M
                                Msayed25say
                                so the plugin does not work offline?!
                                • fredo6F
                                  fredo6
                                  NEW RELEASE: JointPushPull Interactive v4.9a - 02 Apr 25
                                  JointPushPull Interactive 4.9a is a major release including:
                                  • Trimming and Hole Extrusion
                                  IMPORTANT: JointPushPull 4.9a requires LibFredo6 15.3 or above
                                  See plugin home page of JointPushPull for Download of JointPushPull.
                                  Main Post of the JointPushPull thread on this forum
                                  • Gus RG
                                    Gus R
                                    I don't know what I changed but I'm suddenly getting like beveled offset when using Joint Push Pull. Just the regular Joint Push Pull.
                                    www.instagram.com/gusrobatto/
                                    www.facebook.com/gusrobatto
                                    Gus RG 1 Reply Last reply
                                    • Gus RG
                                      Gus R @Gus R
                                      @Gus-R Never mind.
                                      • F
                                        ferol
                                        I just bought the plugin and am testing it. I thought I could replace the classic push-pull with some of its functions, but I have a problem: when I "push" inside an object, the surface often disappears. I made a short video about it:
                                        The only icons that don't do this are "R" and "F."
                                        Is this a bug?
                                        • F
                                          ferol
                                          Is this a bug?
                                          • 27
                                          • 28
                                          • 29
                                          • 30
                                          • 31
                                          • 31 / 31
