    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 949.6k Views 155 Watching
    • A
      Ahmed0007
      @dave r said:
      You never answered my question about proper installation of SketchUp. Did you install SketchUp 2018 and 2019 correctly?
      sorry i don't remember that how i had installed.
      but give main an hour to reinstall as you said.
      • TIGT
        You do not need to 'reinstall'.
        Login as your normal Windows user-account.
        Ensure SketchUp is closed.
        Find the SketchUp installer file's exe icon - it's probably in your Downloads folder.
        Then select it, right-click > context-menu > "Run as administrator"
        When prompted choose "Repair"
        Done.
        It will not harm your existing set up - just 'repair' it, if that is necessary
        • A
          Ahmed0007
          Done.
          oh! Thanks πŸ‘
          • A
            Ahmed0007
            i have done proper installation of SketchUp.
            and i have still same issue.
            • fredo6F
              fredo6
              Since the bugsplat is reproducible on your environment and is not on Dave's or mine, there must be something on your side, possibly a conflict with another plugin (maybe a redefinition of random methods).
              If you have time, could you remove suspicious plugins, in general not mainstream, and check if you get the bug splat.
              Many thanks
              Fredo
              • A
                Ahmed0007
                Many thanks
                Fredo
                i already tried with only JPP and fredoLib installed. but this also not work.
                but you're right there is something wrong with my pc.
                today i tested JPP on my brother pc and it's working fine there.
                i don't know what i should do to fix this issue.
                reinstall windows?
                any suggestion?
                and Thanks for your time.
                • fredo6F
                  fredo6
                  No need to reinstall Windows...
                  Did you try with another model file?
                  Also, can you confirm that
                  • you get the bugsplat only when using the Random feature of JPP
                  • whether this happens for both Normal and Joint tools (since both have a random option)
                  Fredo
                  • A
                    Ahmed0007
                    Fredo
                    with all JPP tools and with any model
                    Video : https://streamable.com/upjw5
                      When you get the Bug Splats are you sending them in with your e-mail address attached? As a licensed SketchUp Pro user with up-to-date Maintenance and Support, you could file a ticket with their Technical Support folks and ask them to look at the Bug Splat reports and decipher what is happening to cause the splat. At this point, since you seem to be the only one having a problem and we can't reproduce the Bug Splats even with your file, more information is needed.
                      • A
                        Ahmed0007
                        @ahmed0007 said:
                        Getting a bugsplat when trying to change the random push pull values. in sketchup 2019 and 18
                        any solution?
                        problem fixed after doing following steps:
                        Uninstall sketchup (2019 and 18) with revo uninstall (also delete Leftovers items and registry files)
                        Reinstall only su19
                        after opening first time this give me this error "mfc140u.dll" Missing
                        install Visual C++ Redistributable for Visual Studio 2015
                        and
                        uninstall Visual C++ Redistributable for Visual Studio 2017
                        Done!
                        Thank you Fredo6 and Dave R for response.
                        • fredo6F
                          fredo6
                          Glad to see that it now works for you.
                          Still, this is puzzling, and I don't really see why JointPushPull would specifically crash in relation to the version of C++, since it is pure Ruby.
                          • BoxB
                            Hi Fredo,
                            I was just doing a gif to show something in JPP and noticed it breaks the dimension connection.
                            Checked 2018,19,20.
                            FredoScale for example doesn't break the connection.
                            Not sure if it has always been that way and I just don't remember it being like that.
                              Breaking also in the 2017! πŸ˜‰
                              • fredo6F
                                fredo6
                                JointPushPull technically creates faces (and thus new vertices), whereas FredoScale just uses a scaling transformation and therefore keeps the faces and vertices homologous.
                                JointPushPull does not use native pushpull methods, due to the fact that it is multi-face tool.
                                So it is normal that JPP loses the dimension connections.
                                Reconstructing them is maybe possible, but probably some work due to the variety of topological situations, and also the poor support of the API for dimensions. I have to check if the connections are exposed in the API and can be reconstructed.
                                EDIT: just checked that for linear dimensions, there is a possibility to manage the attachment, but as of SU2019.
                                • BoxB
                                  Thanks for letting me know, I was just pointing it out incase it was a bug, just one of those things I hadn't noticed before.
                                  • H
                                    hugoakio
                                    I need a help. I'm trying to export an object and experimenting the folling error at the "erase coplanar edges":
                                    An error occurred in Round Push Pull
                                    Error in generation of the geometry
                                    reference to deleted Entity
                                    jointpushpullgeometry.rbe: 1023 -- entityID
                                    jointpushpullgeometry.rbe: 1023 -- block in geometry_coplanar_edges
                                    jointpushpullgeometry.rbe: 1020 -- each
                                    jointpushpullgeometry.rbe: 1020 -- geometry_coplanar_edges
                                    jointpushpullgeometry.rbe: 366 -- block in geometry_robot_erase_coplanar_edges
                                    jointpushpullgeometry.rbe: 362 -- each
                                    jointpushpullgeometry.rbe: 362 -- geometry_robot_erase_coplanar_edges
                                    jointpushpullgeometry.rbe: 220 -- robot_call_action
                                    jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
                                    jointpushpullgeometry.rbe: 166 -- geometry_robot
                                    jointpushpullgeometry.rbe: 81 -- block in geometry_execute
                                    lib6operation.rbe: 370 -- step_geometry
                                    lib6operation.rbe: 305 -- block in yield?
                                    What i'm doing wrong?
                                    • fredo6F
                                      fredo6
                                      Nothing a priori.
                                      I have fixed the problem itself (to go in a next version of JPP), but that does not mean you will get a correct result, because you must likely be in a special situation of topology (which RoundPushPull is very sensitive to).
                                      It would help if you posted the model and indicate which operation you were trying to perform.
                                      Fredo
                                      • D
                                        daniabreu1
                                        Hi, I am having a problem with this plugin SU2020 - Trying to use the jointpushpull= and a little grade surface keep showing up and the tool doesn't work. Any solutions?
                                          You've given no useful information making it impossible to help. Share your SketchUp file and give a clear description of what you are trying to accomplish. Also show us what settings you are using with the extension.
                                          • D
                                            daniabreu1
                                            Thanks Dave. Somehow I uninstall it and installed again and it works. Thank you for trying to help tho! πŸ˜„
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 30
                                            • 31
                                            • 22 / 31
