    Eraser Tool, Crtl-Shift does not unsoften edge
    4 Posts 2 Posters 1.2k Views 2 Watching
    • kuponoK Offline
      kupono
      It used to, but recently it just erases the edge. Thoughts?
      SU 2013 Pro
      • TIGT Online
        It still works.
        That is Erase+Ctrl to smooth, & Erase+Ctrl+Shift to undo the smooth.
        Perhaps you will find that as well as being softened/smoothed these 'problem edges' are also 'hidden' [Hide = Erase+Shift].
        They have a slightly different line stipple-style in View > Hidden Geometry ON.
        To check an edge's status switch View > Hidden Geometry ON and Select one of these 'problem edges'.
        'Entity Info' will then show its smooth/soft/hidden status in check-boxes at the bottom of the dialog.
        Untick a check-box a status to reset it.
        You can select all edges in one go and use the context-menu 'Unhide' to do a reset too.
        Unfortunately, unlike 'Smooth/Unsmooth', there is no equivalent key-combo when using Erase to 'Unhide' things...
        • kuponoK Offline
          kupono
          Yup, that's how used to work until recently. Now Erase+Ctrl+Shift erases the edge instead of undoing the smooth. I've tried different keyboards, rebooted, tried it on multiple files...
          Test.skp
          • TIGT Online
            So, something is wrong with your SketchUp installation, or your Keyboard or its key-mapping !
            Using Erase+Ctrl+Shift works fine for me in unsmooth/unsoftening edges.
            I have the latest v2103 [although that should not matter as it has always worked faultlessly]
            Have you considered doing a 'Repair' or failing that fixing things a 'Reinstall' ?
