    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 211.8k Views 84 Watching
      markitekt
      I'm getting numerous errors when loading (double clicking) a skp file from a network location (ver. 2014). I had similar errors earlier with some of Thom Thom's plugins which he resolved. It loads fine from the desktop or on my computer locally. Only issues when selecting from a network location.
      Thanks,
      Mark
      • G Offline
        Gábor
        To me, it sounds similar to this solved issue: http://sketchucation.com/forums/viewtopic.php?p=519331#p519331
        • W Offline
          whiteanne
          The latest version can't work on my sketchup 2013,but V2.5.1 did.another way,V2.6 works great on 2014.pls fix it.
            @whiteanne said:
            The latest version can't work on my sketchup 2013, but V2.5.1 did.another way,V2.6 works great on 2014. pls fix it.
            It should work on v2013.
            How doesn't it work ?
            You report doesn't help us to help you 😒
            What fails ?
            What errors etc...
            • W Offline
              whiteanne
              What fails ?
              What errors etc...
              With very long loading time,then crushed.
              • G Offline
                Gábor
                What does "crushed" mean? Error message? Bugsplat? Frozen SketchUp?
                Sorry but we never met this kind of error so we need some more info to get a clue about the nature of the problem.
                  It means 'crashed' ! 😒
                  I have had a PM exchange to see if there is an anti-virus app blocking the v2013 vbs data pingers etc...
                  I await a response... 😕
                    Jim
                    Would it be possible to have a filter reset located right around here somewheres:
                    • I Offline
                      izeric
                      Hello. I can't seem to install (auto-install) from the plugin store. Nothing happens when i click Autoinstall. I've set permissions in the plugin folder to full control already. Any help with this? Thanks
                        What if you provide some useful information such as SketchUp version and operating system? That would help us help you.
                        • Rich O BrienR Online
                          Also, your in the 2.0 thread and that no longer works.
                          We are using 2.6
                          • O Offline
                            obang12
                            Been entered in the wrong account
                            Can not log out
                            How do I log out
                              V2.0 is no longer in use.
                              Please upgrade to 2.6
                              • O Offline
                                obang12
                                using version 2.6
                                answer me~plz
                                How do I log out?
                                  There is no simple 'log-out'.
                                  Run this line of code in the Ruby Console [edit>copy+edit>paste+<enter>].
                                  File.delete(File.join(SCF_Dialog;;SCFDIR,'cookie.dat'))
                                  It deletes you current login data, You will then be prompted to log-in again when you next use the SketchUcation PluginStore dialog...
                                  You must use a valid SketchUcation member-name and its password...
                                  • O Offline
                                    obang12
                                    Tried to solve the problem
                                    Thank you 😉
                                      matt.gordon320
                                      Hi guys! Fantastic job on the plugin, I use it almost daily.
                                      I wanted to throw out a request, see if it makes sense. I use SketchUcation Tools to manage and install plugins across a network, with people on SketchUp 8 and 2014. I've got some pro users who know how to use many plugins, some newbies who don't, and several different departments who have different needs. I use Fredo's Additional Locations Script to point to different directories on the network as well.
                                      Would there be any benefit to adding a section where you can define your own "packages" as it were, so that I could create batch installs for user definable groups. For instance, I could make a package with some of ThomThom's scripts that we use, so that I could batch install those to a single location? I'd like to have a package I could install for out Land Planning Department, one for design, etc.
                                      Also, I thought I'd mention that the current AutoInstall window doesn't fit everything if you have a fairly long path. Not a problem since it sorts alphabetically, but thought I'd mention it.
                                      Long file paths get clipped
                                      Thanks, and keep up the great work. I can elaborate more if it helps!
                                      Matt
                                        You could of course choose more snappy folder names ?
                                        N:/SUp/Plugins/Network/Ruby20/xxx/...
                                        You seem to use very loooong paths... Windows does have <= ~255 characters limit too !
                                          matt.gordon320
                                          LOL Yes. Getting by the upper management sometimes is the issue. "It should be clear to everyone what it is..blah blah blah" 😒
                                          • shake1S Offline
                                            shake1
                                            Help!
                                            Unzip error: could not unzip archive
                                            Win 7 x64, With the latest updates.
                                            http://i.imgur.com/2zxf6iR.jpg
                                            In sketch2013 works fine, in Sketch 2014, also worked, and then stopped, I do not know why.
                                            Not update, not install new plugins, - always Unzip error.
                                            A plug-ins folder correct (C:/Users/Shake/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins)
                                            Permissions for the Plugins folder correct.
                                            Internet Explorer With the latest updates.
                                            Tried a clean install without any plug-in, the same result - does not work.
                                            Help, I go crazy, I can not understand why stopped working
                                            SketchUcation_Usage.log
                                            2014-10-10 05;10;54 +0700=GOT_OPEN_URI=true
                                            2014-10-10 05;10;54 +0700=GOT_RUBYZIP=true
                                            2014-10-10 05;10;58 +0700=skecthUcloud-is_enabled?false
                                            2014-10-10 05;10;59 +0700=SCFapi-enabled?true
                                            2014-10-10 05;10;59 +0700=SCFapi-verbose?false
                                            2014-10-10 05;11;04 +0700=PluginStore-Run
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 19
                                            • 20
                                            • 11 / 20
