    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 264.1k Views 84 Watching
    • W
      whiteanne
      The latest version can't work on my sketchup 2013,but V2.5.1 did.another way,V2.6 works great on 2014.pls fix it.
        @whiteanne said:
        The latest version can't work on my sketchup 2013, but V2.5.1 did.another way,V2.6 works great on 2014. pls fix it.
        It should work on v2013.
        How doesn't it work ?
        You report doesn't help us to help you 😒
        What fails ?
        What errors etc...
        • W
          whiteanne
          What fails ?
          What errors etc...
          With very long loading time,then crushed.
          • G
            Gábor
            What does "crushed" mean? Error message? Bugsplat? Frozen SketchUp?
            Sorry but we never met this kind of error so we need some more info to get a clue about the nature of the problem.
              It means 'crashed' ! 😒
              I have had a PM exchange to see if there is an anti-virus app blocking the v2013 vbs data pingers etc...
              I await a response... 😕
                Jim
                Would it be possible to have a filter reset located right around here somewheres:
                • I
                  izeric
                  Hello. I can't seem to install (auto-install) from the plugin store. Nothing happens when i click Autoinstall. I've set permissions in the plugin folder to full control already. Any help with this? Thanks
                    What if you provide some useful information such as SketchUp version and operating system? That would help us help you.
                      Also, your in the 2.0 thread and that no longer works.
                      We are using 2.6
                      • O
                        obang12
                        Been entered in the wrong account
                        Can not log out
                        How do I log out
                          V2.0 is no longer in use.
                          Please upgrade to 2.6
                          • O
                            obang12
                            using version 2.6
                            answer me~plz
                            How do I log out?
                              There is no simple 'log-out'.
                              Run this line of code in the Ruby Console [edit>copy+edit>paste+<enter>].
                              File.delete(File.join(SCF_Dialog;;SCFDIR,'cookie.dat'))
                              It deletes you current login data, You will then be prompted to log-in again when you next use the SketchUcation PluginStore dialog...
                              You must use a valid SketchUcation member-name and its password...
                              • O
                                obang12
                                Tried to solve the problem
                                Thank you 😉
                                  matt.gordon320
                                  Hi guys! Fantastic job on the plugin, I use it almost daily.
                                  I wanted to throw out a request, see if it makes sense. I use SketchUcation Tools to manage and install plugins across a network, with people on SketchUp 8 and 2014. I've got some pro users who know how to use many plugins, some newbies who don't, and several different departments who have different needs. I use Fredo's Additional Locations Script to point to different directories on the network as well.
                                  Would there be any benefit to adding a section where you can define your own "packages" as it were, so that I could create batch installs for user definable groups. For instance, I could make a package with some of ThomThom's scripts that we use, so that I could batch install those to a single location? I'd like to have a package I could install for out Land Planning Department, one for design, etc.
                                  Also, I thought I'd mention that the current AutoInstall window doesn't fit everything if you have a fairly long path. Not a problem since it sorts alphabetically, but thought I'd mention it.
                                  Long file paths get clipped
                                  Thanks, and keep up the great work. I can elaborate more if it helps!
                                  Matt
                                    You could of course choose more snappy folder names ?
                                    N:/SUp/Plugins/Network/Ruby20/xxx/...
                                    You seem to use very loooong paths... Windows does have <= ~255 characters limit too !
                                      matt.gordon320
                                      LOL Yes. Getting by the upper management sometimes is the issue. "It should be clear to everyone what it is..blah blah blah" 😒
                                      • shake1S
                                        shake1
                                        Help!
                                        Unzip error: could not unzip archive
                                        Win 7 x64, With the latest updates.
                                        http://i.imgur.com/2zxf6iR.jpg
                                        In sketch2013 works fine, in Sketch 2014, also worked, and then stopped, I do not know why.
                                        Not update, not install new plugins, - always Unzip error.
                                        A plug-ins folder correct (C:/Users/Shake/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins)
                                        Permissions for the Plugins folder correct.
                                        Internet Explorer With the latest updates.
                                        Tried a clean install without any plug-in, the same result - does not work.
                                        Help, I go crazy, I can not understand why stopped working
                                        SketchUcation_Usage.log
                                        2014-10-10 05;10;54 +0700=GOT_OPEN_URI=true
                                        2014-10-10 05;10;54 +0700=GOT_RUBYZIP=true
                                        2014-10-10 05;10;58 +0700=skecthUcloud-is_enabled?false
                                        2014-10-10 05;10;59 +0700=SCFapi-enabled?true
                                        2014-10-10 05;10;59 +0700=SCFapi-verbose?false
                                        2014-10-10 05;11;04 +0700=PluginStore-Run
                                          matt.gordon320
                                          I wanted to see if I could also request that the version compatibility be put in at a glance if possible from the main store window. It shows downloads, and sometimes usage, but it'd be nice to show compatibility too for installing across multiple versions.
                                          • G
                                            Gábor
                                            @shake1: PM was sent to you.
                                            @matt.gordon320: Thank you for the good ideas. You might see these features in the 3.0 version coming soon. 😄
                                            • 11
                                            • 12
                                            • 13
                                            • 19
                                            • 20
                                            • 11 / 20
