    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 211.9k Views 84 Watching
    • I Offline
      izeric
      Hello. I can't seem to install (auto-install) from the plugin store. Nothing happens when i click Autoinstall. I've set permissions in the plugin folder to full control already. Any help with this? Thanks
        What if you provide some useful information such as SketchUp version and operating system? That would help us help you.
          Also, your in the 2.0 thread and that no longer works.
          We are using 2.6
          • O Offline
            obang12
            Been entered in the wrong account
            Can not log out
            How do I log out
              V2.0 is no longer in use.
              Please upgrade to 2.6
              • O Offline
                obang12
                using version 2.6
                answer me~plz
                How do I log out?
                  There is no simple 'log-out'.
                  Run this line of code in the Ruby Console [edit>copy+edit>paste+<enter>].
                  File.delete(File.join(SCF_Dialog;;SCFDIR,'cookie.dat'))
                  It deletes you current login data, You will then be prompted to log-in again when you next use the SketchUcation PluginStore dialog...
                  You must use a valid SketchUcation member-name and its password...
                  • O Offline
                    obang12
                    Tried to solve the problem
                    Thank you 😉
                      matt.gordon320
                      Hi guys! Fantastic job on the plugin, I use it almost daily.
                      I wanted to throw out a request, see if it makes sense. I use SketchUcation Tools to manage and install plugins across a network, with people on SketchUp 8 and 2014. I've got some pro users who know how to use many plugins, some newbies who don't, and several different departments who have different needs. I use Fredo's Additional Locations Script to point to different directories on the network as well.
                      Would there be any benefit to adding a section where you can define your own "packages" as it were, so that I could create batch installs for user definable groups. For instance, I could make a package with some of ThomThom's scripts that we use, so that I could batch install those to a single location? I'd like to have a package I could install for out Land Planning Department, one for design, etc.
                      Also, I thought I'd mention that the current AutoInstall window doesn't fit everything if you have a fairly long path. Not a problem since it sorts alphabetically, but thought I'd mention it.
                      Long file paths get clipped
                      Thanks, and keep up the great work. I can elaborate more if it helps!
                      Matt
                        You could of course choose more snappy folder names ?
                        N:/SUp/Plugins/Network/Ruby20/xxx/...
                        You seem to use very loooong paths... Windows does have <= ~255 characters limit too !
                          matt.gordon320
                          LOL Yes. Getting by the upper management sometimes is the issue. "It should be clear to everyone what it is..blah blah blah" 😒
                          • shake1S Offline
                            shake1
                            Help!
                            Unzip error: could not unzip archive
                            Win 7 x64, With the latest updates.
                            http://i.imgur.com/2zxf6iR.jpg
                            In sketch2013 works fine, in Sketch 2014, also worked, and then stopped, I do not know why.
                            Not update, not install new plugins, - always Unzip error.
                            A plug-ins folder correct (C:/Users/Shake/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins)
                            Permissions for the Plugins folder correct.
                            Internet Explorer With the latest updates.
                            Tried a clean install without any plug-in, the same result - does not work.
                            Help, I go crazy, I can not understand why stopped working
                            SketchUcation_Usage.log
                            2014-10-10 05;10;54 +0700=GOT_OPEN_URI=true
                            2014-10-10 05;10;54 +0700=GOT_RUBYZIP=true
                            2014-10-10 05;10;58 +0700=skecthUcloud-is_enabled?false
                            2014-10-10 05;10;59 +0700=SCFapi-enabled?true
                            2014-10-10 05;10;59 +0700=SCFapi-verbose?false
                            2014-10-10 05;11;04 +0700=PluginStore-Run
                              matt.gordon320
                              I wanted to see if I could also request that the version compatibility be put in at a glance if possible from the main store window. It shows downloads, and sometimes usage, but it'd be nice to show compatibility too for installing across multiple versions.
                                Gábor
                                @shake1: PM was sent to you.
                                @matt.gordon320: Thank you for the good ideas. You might see these features in the 3.0 version coming soon. 😄
                                  acatalyst
                                  how do yo log out of the plugin in SketchUp? I need to change user accounts
                                    Gábor
                                    The current version of the plugin has no log out feature. I'll PM you a method what will let you to log in with an other account.
                                      acatalyst
                                      i actually figured it out. thank you.
                                      i wish there was a "logout feature"
                                      • shake1S Offline
                                        shake1
                                        I'm sorry I can not answer in a personal, if you do not mind I'll answer here
                                        @gábor said:
                                        I have some questions regarding your error. Please answer them to let us find the reason:
                                        Did you have the same problem with the previous (v.2.6.0) version of the plugin?
                                        Do you have this unzip issue only with one specific plugin file or installing any plugin throws this error?
                                        What happens when you download the .rbz file and manually install it at Preferences/Install Extension?
                                        • version 2.6.0 had the same problem
                                        • this error when installing/updating any plug
                                        • each file is installed successfully from Preferences/Install Extension
                                        AND... if you have the Ruby Console open, are there any messages ?
                                        Also, if you download some RBZ files can you auto-install using SketchUcation / Install Archive... submenu item ?
                                        • Ruby console does not display any messages
                                        • from SketchUcation / Install Archive... installed without problems
                                          Gábor
                                          Collecting the good ideas for the next release. Log out feature is one of them. 😄
                                            Gábor
                                            @shake1: Thank you for the answers. We are looking for the possible cause. Will let you know if we have any other questions or if we have the fix for it.
                                            • 11
                                            • 12
                                            • 13
                                            • 19
                                            • 20
                                            • 11 / 20
