    [Request] A one button texture rotate solution
    17 Posts 8 Posters 1.4k Views 8 Watching
    • N Offline
      numerobis
      The ability to assign a 90Β° texture rotation to a button.
      This is still not available, right? Or did i miss something?
      Is this really so diffucult to program?!? I can't believe it when i look at all these complex plugins.
      A simple shortcut for direct access of the texture rotate options hidden deep in the right click menu of the texture position function would be enough...
      • renderizaR Offline
        renderiza
        TIG developed TextureTools v1.5 ... http://sketchucation.com/forums/viewtopic.php?p=329765#p329765
        Feature that will work with arrow keys:
        • TextureRotate
        • TextureAdjust
        • TextureShunt
        • TextureNudge
        • TextureScale
        • TextureTweak
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • N Offline
          numerobis
          sorry, i don't get it... how can i use the arrow keys?
          and
          To run the Tool without a dialog you can use 'TextureTools::Rotate.new(45)' -
          where the angle is passed directly to the texture, in this case it is
          45 degrees; this allows the texture-rotation to be run from within another
          tool which passes an angle directly to it without an interrupting dialog.
          where can i "use 'TextureTools::Rotate.new(45)'" ? πŸ˜•
          If this yould work it would at least be a 'two button' solution...
            [screenr:3hwp1jfv]Od4H[/screenr:3hwp1jfv]
            • N Offline
              numerobis
              i know Fredo's ThruPaint - great Tool! - but what i want is a simple 90Β° rotation by pressing a key... not possible?
              • pbacotP Offline
                You activate ThruPaint with a key then right click gives a 90 deg choice. That's getting closer..
                • N Offline
                  numerobis
                  Thanks! but it's not really faster than accessing the texture positioning with a shortcut and then using the right click.
                  • iichiversiiI Offline
                    iichiversii
                    Texture a plane, make a component, rotate 90degrees, explode, copy texture and there ya have it, works for me every time
                    Bring on the Rain...
                      For wood grain materials I generally only need to rotate a material once so using the native Texture tools to do it is no real inconvenience even when there are a number of different materials in the model. Once I have a vertical and a horizontal example in the model space, I just sample those as needed for the rest of my painting.
                        iichiversii
                        I'm guessing that he wants to use 1 texture, I maybe wrong tho, but if your using 1 texture and want to export the model without the added extra unique textures and so on I find my technic works, sometimes adjusting pins can accidentally alter the scale of the texture and that makes another texture, I don't think I can rotate a texture without adjusting the pins, which I recommend against, apply the texture to a plane, make it a component which will lock the texture to that surface, explode that same component and copy the texture from the surface and the rotation will be what you need, but also bare in mind if you adjust the scale then SU will automatically create a unique texture if you export the model, but then again I could be wrong to what he actually wants, lol
                        • N Offline
                          numerobis
                          there is no question that it "works" as it is now with the native tool and with the fabulous ThruPaint for more complex shapes or complete objects. I just can't understand that after such a long time there is still no shortcut or a plugin for this little function... Every time i have to rotate a texture i'm thinking about it. Sure, i can "rotate" the texture by painting the faces of an object in the right order or pic the texture from another face with the right direction. I just thought it could be easier - but it seems that i'm the only one πŸ˜†
                          I have assigned the 'invert faces' command to the '^'-key so that i can switch the orientation while i model. This would be a similar thing for texturing.
                            I'm only using one texture and not making any unique textures. For 90Β° (or 180Β° and 270Β°) rotations there's no need to touch the pins. Just right click again and hit Rotate and the angle. I don't ever find any need to make and then explode a component either. Certainly not so I can get the orientation as you describe.
                            • N Offline
                              numerobis
                              @dave r said:
                              Get the Paint Bucket, hold Alt to sample the material and its orientation let go of Alt and apply it. If you preselect all the faces in the component, you only need to click once to apply the same material all the way around it.
                              Thanks, but my question was not how to apply a material - i'm using SU since v2... πŸ˜‰
                              • pbacotP Offline
                                Such a common operation. There should be one. If there were a "Texture" menu or submenu, then this could be done. The menu could hold the future mapping commands that TT will bring to SU too!
                                • Jean-FrancoJ Offline
                                  Jean-Franco
                                  Maybe this plugin from Julia Eneroth can help ?
                                  You just select the texture on your face and click the right or left icon in the toolbar.
                                  http://eneroth.port0.org/plugins/texturerotater/
                                  It's also available from Plugin Store.
                                  Jean-Franco
                                  • fredo6F Offline
                                    fredo6
                                    ThruPaint includes some ways to rate textures by 90Β° (and 180Β°).
                                    • VCB: + or -
                                    • the small texture edition palette has buttons for rotations
                                    Fredo
                                    • N Offline
                                      numerobis
                                      Wow! Great! There it is... i assigned some shortcuts and it works! Thank You! πŸ˜„
                                      (i just had to rename one function from "Counter Clockwise" to "Clockwise" because they were named the same in the .rb.)
                                      • VCB: + or -
                                      Fredo
                                      Thanks Fredo! I tried the +/- thing before, but i wasn't aware that i have to hit enter to make it work! πŸ˜† 😳
                                      So there is another solution for use with ThruPaint. 😎
