    Sketchup rounds to 0.1 inch
    11 Posts 5 Posters 2.2k Views 5 Watching
      scott216
      I have a circle and I'm trying to change the radius from 4.4 to 4.35. But when I do Sketchup rounds it to 4.4 inches. I can't get any resolution finer then 0.1". I've changed the precision setting in Model info, but that doesn't help. I set it to the finest decimal setting. Also also tried fractions and set it to 1/64", but sketchup just rounds it to 1/2 inch. This isn't for all objects. I tried a changing a line it it worked normally. But when I do it for circles, it keeps rounding to 0.1"
      I've got Sketchup 8 (free version)running on Window 7.
        How are you trying to change the radius? Do you have length snapping enabled? Are you setting the radius after you have changed the units and precision?
        I'm not having any difficulty.
          scott216
          Yes, I'm trying to change the radius by typing in a new radius in the entity info box. Length snapping is disabled. I changed the precision, then I tried to change the radius, but it rounded it to 1/10 inch. I even created a new circle and again it rounds it. If I create a straight line I can get it more precise then 1/10. I'm only having the problem with a circle. I haven't tried other shapes.
          I tried this on a different computer (also SU 8 on Win 7) and I don't have this problem, it works normally. It seem to be just this one computer. I did try rebooting it, but that didn't help.
            mrossk
            It sounds like you need to alter your "precision setting" under Window/Model Info
            https://www.mkaplanfinefurniture.com/
              Michael, that was my first thought but he says he tried to set precision higher.
              Scott, are you setting the precision high before trying to make the adjustment? Perhaps you could post a sample model in which the resize fails?
                scott216
                Here's the file I was using.
                Here's the model I'm having problems with. I tried changing radius to 4.35" but it keeps rounding to nearest tenth
                  Is the circle you want to change? I didn't do anything but open the file and it shows 4.350" for the radius.
                  • BoxB Offline
                    Plus it is possible to alter the other circles, down to .001
                    • jeff hammondJ Offline
                      jeff hammond
                      fwiw, you can't change the precision or tolerance in sketchup as you can with other cad apps.. it's always .000001
                      you can change the display precision.. apparently, your display precision is stuck on a certain decimal and is being rounded.. (though the actual precision of the drawing is still going to a millionth unit-- as in, your file is showing the proper measurement of 4.35 on other people's computers even though yours is rounding the display to 4.4..
                      i know this isn't answering your question or fixing your problem but just putting it out there in case you need to get on with your work for the time being..
                      dotdotdot
                        scott216
                        I tried the same file on other computers and it's fine. Something is up this my one computer. I upgraded to Sketchup Make and it works fine with thiat.
                          jeff hammond
                          possibly a corrupted .plist (or whatever the windows equivalent may be called)
                          you could maybe try a 'reset workspace' to see if it jars the entity info panel into proper behavior (preferences->workspace->reset workspace) ?
                          does it do the same thing in the measurement box or with dimensions?
                          dotdotdot
