    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 280.2k Views 110 Watching
      breezy
      JBB,
      Thank you for designing the Layers panel, it is great to be able to nest layers. 😍
      But when I tried to remove a layer and delete the contents Sketchup throws a Bug Splat. 👎
      This happened first with 0.2 but again with 0.3.1. I am using Sketchup 2013. The layer that I tried to delete had no components assigned to it. I had the Outliner window open and just before the bug splat was thrown I noticed a bundle of groups appear on the bottom of the Outline tree. The model statistics are 201 components definitions, 35 layers, 31 materials all created before installing Layers panel. Some of the layers were hidden at the time of the bug splat. I submitted the bug splat #43650, if it is any help I still have a copy of the splat files Undo.log, Sketchup.dmp and .xml.
      Regards,
      Arie.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Bimbalas > I'll look at non-ASCII characters.
        Breezy > That's a known bug and Dan helped me fix it : http://sketchucation.com/forums/viewtopic.php?f=180&t=54161
        It will be fixed in the next release (out in a few days)
          breezy
          jiminy-billy-bob,
          Thank you. I refrain from using your delete button!
          A possible future feature is the ability to colour the layers as in Sketchup's layers window. Also to rollup the window by clicking on the title bar.
          Thanks again for what you have produced, I have found it easier to control the layers in my projects. 😍
          Regards,
          Arie.
          • MichaelNeysesM Offline
            MichaelNeyses
            Ive got some problems with the layer panel.
            1. It is asking for me to update the current ie explorer. But i already installed version 10 although it is not my standard browser, which is firefox.
            2. When I use the features as explained s. a . creatíng groups and layers and sort the whole structure, then i will not be able to open this very drawing again after saving and closing it properly. The comment is: ²wrong file format!² , the file is actally lost.
              I am glad i did not blindly change any important file and put too much time in doing so.
              Glad there is a thing called .skb! I think this is a rather serious issue.
              I wonder if i am the only one with this experience!
            Michael
            nothing beats the joy of accomplishing a design that meets previous vision
              jiminy-billy-bob
              Unfortunatly, the API doesn't allow me to do that...
              Can you go to http://whatsmyua.com/ with Internet Explorer, and tell me what it says ?
              1. When I use the features as explained s. a . creatíng groups and layers and sort the whole structure, then i will not be able to open this very drawing again after saving and closing it properly. The comment is: ²wrong file format!² , the file is actally lost.
              Did you create these groups with a version of Layers Panel older than 0.3.1 ? Like 0.2, 0.3, etc
              • cmeedC Offline
                cmeed
                I'm having issues with renaming layers - only some though others work fine.
                deleting layer and starting again this dosen't happen - I can rename again
                (i didn't have to make a video for this but I've never done it, so there you go....)
                  jiminy-billy-bob
                  Is it renamed in SU's layer window ?
                  • cmeedC Offline
                    cmeed
                    I didn't see but this isn't the fist time this has happened so will keep a better note next time.
                    • gullfoG Offline
                      gullfo
                      i've found an issue? i added layers after placing a bunch into groups and when i drag the unassigned layer into a group i get a javascript error. attached is the file and the screenshot. i'm using SU 2013 pro 13.0.4812 on Windows Vista SP2. i have full permission in SU prog dir.
                      screenshot of error
                      sketchup file
                      Glenn
                      http://www.runnel.com
                        jiminy-billy-bob
                        Ok, thanks.
                        I think it's related to Observers watching layers change. I had these kind of issue in the past and resolved a lot of them, but it's possible that some remain. If it's indeed related to observers, it should occur only with old layers created before Layers Panel was installed.
                        gullfo > I'll look at your file.
                          jiminy-billy-bob
                          Ok Glenn, I found the issue. You simply have too many layers. It's related to the max length a url can pass between the dialog and SU. I forgot about this... I'll need to rewrite some code.
                          • cmeedC Offline
                            cmeed
                            Thats it- it was an old layer. The reason i was changing it was to give it a capital letter, I started out with non-capitalised layer names......
                            • cmeedC Offline
                              cmeed
                              does that mean theres a limit on layers?
                              c
                                jiminy-billy-bob
                                For now, yes. I had this planned, but completely forgot about it. So I don't know the current limit. But in next version, it should be fixed.
                                • gullfoG Offline
                                  gullfo
                                  no problem! that's what beta-testing is all about 😄
                                  Glenn
                                  • gullfoG Offline
                                    gullfo
                                    that's the short list 😄 once you start to use ACAD standard architecture layer sets it gets "big"
                                    Glenn
                                      jiminy-billy-bob
                                      @bimbalas said:
                                      On renamaming layers or groups directly on Layers Panel with letters from non ASCII character set (e.g. ąžįėš) this letters was changed to unicode codes.
                                      I just tested, and it works for me when I rename a layer to "ąžįėš". Which versions of Sketchup, windows, and internet explorer are you using ?
                                        jiminy-billy-bob
                                        New version 0.3.2 beta !
                                        Changelog :
                                        • Fix bugsplat when deleteing/purging layers with Outliner opened
                                        • New naming conventions (For the Extension Warehouse)
                                        Download in the plugin store !
                                        At startup, you should get once "Error Loading File layers_panel.rb no such file to load -- layers_panel.rb". This is normal, it's just the plugin deleting the old files.
                                        • cmeedC Offline
                                          cmeed
                                          this is with release 0.3.2
                                          same naming issue with names not changing in the LayersPanel - they are changing in the Layers Window though
                                          I updated the plugin this morning. The layers were made yesterday. I closed down SU. restarted SU. captured film so its not happening with the layers or folders before the plugin was installed, as all were made yesterday
                                          C
                                          EDIT: in the time its taken me to write the above the layer has now changed to 'hello' in LayersPanel. just so you know...
                                          • tt_suT Offline
                                            tt_su
                                            Doh! I was just about to look at this.
                                            Can you PM me the old version that crashed? I'd like to have a look at it.
                                            (Also, what did you do to avoid the crash?)
                                            • 6
                                            • 7
                                            • 33
                                            • 34
                                            • 5 / 34
