    How to make a LED light stripe?
    renderpluginsextensions
    14 Posts 5 Posters 13.0k Views 5 Watching
    • V Offline
      Vejlstrup
      Hello all.
      I'm trying to make a LED light stripe, but it won't enlighten the wall it's attached to, only light up the roof.
      The stripe is actually just a list with a 1 cm LED-stripe in it.
      See image for reference.
      Thanks.
      Andreas
      • ToboboT Offline
        Tobobo
        Can you post the model?
        Toby
        Philippians 4:13
        • V Offline
          Vejlstrup
          Yes, sure. See link: https://www.dropbox.com/s/c758qs4tqa0rk5l/LED_Stripe_Modelskp.skp
          I've both tried both with a emissive material and rectangle light, both with smaller and wider rectangle stripes.. Nothing seems to really give the wished effect with a gradient light going up the wall.
          Afterwards I'm going to install IES-lights in all the spotlights, so the LED is to make a nice ambient light all around.
          Thank you.
          • ToboboT Offline
            Tobobo
            hey,
            I've had a look at the lights and there is a few things I've changed.
            1. I have purged the file
            2. Flipped the rectangle light so they have their front face up.
            3. Raised and angled the lights towards the wall.
            4. Turn off the 'no decay', 'double sided' and turned up the intensity.
            When I am lighting a room, I classify my lights into three categories:
            1. functional Lighting
            2. Accent lighting
            3. Highlight......lighting
            The LED strips are accent lighting and so shouldn't be used to light the whole room (functional lighting)
            EDIT: I think you need to add some functional lighting as well as the spot lights
            I've attached the jpeg and the file.
            Hope it helps
            LED_Stripe_Modelskp.zip
            Toby
            Philippians 4:13
            • V Offline
              Vejlstrup
              Thank you very much Sir, exactly what I wanted.
              I will see if I can learn from some of your changes.
              In the real room, the funtional light will probably come from the spotlights, but it's not quite sure yet.
              Thank you very much.
              • V Offline
                Vejlstrup
                Can I ask you in which way you purged the file? I used a Cleaner plug-in, but I'm pretty new, so it would be nice to know which function you used.
                  Just use Model Info > Statistics > Purge Unused... to do it to everything.
                  My 'Purge All' tool is very similar... but that allows you to purge only specific types of thing - e.g. 'Layers' - if desired it also can report what it has done in more detail...
                  http://sketchucation.com/resources/pluginstore?pln=PurgeAll
                  • dkendigD Offline
                    dkendig
                    fyi, purging unused materials from the sketchup model, will cause certain V-Ray materials to not function properly. This is because we allow materials to use other materials as sub materials. Sub materials may not be applied to any objects in the SU scene, so it assumes it is safe to purge, even though this will break any materials utilizing that sub material
                    Devin Kendig
                    Developer
                    • jiminy-billy-bobJ Offline
                      jiminy-billy-bob
                      Can't you find a way to prevent this ? Like, if a material has sub-materials, apply it to an empty group.
                      group = Sketchup.active_model.entities.add_group()
                      group.material = mat
                      Or do this temporarly when a "purge materials" button is clicked from the Vray UI. The material would still get deleted when purged from SU's material window, but not from Vray, and you wouldn't pollute the model.
                      I use a similar snippet from TIG for my own plugin, but with layers.
                      • dkendigD Offline
                        dkendig
                        we handle a purge unused properly when you use our UI, but no, we aren't going to litter a SketchUp model with empty groups to prevent the native purge unused tool in SketchUp from removing materials that are used as sub materials. SketchUp needs a way to mark a material as being used, or an observer that allows us to handle that function, once they add that ability, we will support their native tool.
                        Devin Kendig
                        Developer
                          jiminy-billy-bob
                          Ho sweet, I didn't know !
                          • ToboboT Offline
                            Tobobo
                            TIG's tool is the one i use to get around the VRay linking of sub materials, i just remove material from the 'to be purged' list
                            Toby
                            Philippians 4:13
                            • dkendigD Offline
                              dkendig
                              That isn't necessary if you use the purge unused option in the V-Ray material editor
                              Devin Kendig
                              Developer
                              • ToboboT Offline
                                Tobobo
                                What I meant was I use TIG's plugin to purge the model of everything else without losing the VRay materials.
                                Toby
                                Philippians 4:13
