    Layout 2013 crashes on start
    layout
    29 Posts 10 Posters 6.2k Views 10 Watching
      Ensure your user-name has no non-ASCII characters in it - i.e. no accented letters etc. 😕
      • La DuFL Offline
        La DuF
        Hello, Tig !!
        Mine has (François) and this cannot be changed...
        Anything else I could try ?
          That is probably it ! 😕
          Not even to Francois ?
          Can't it be changed in the Users control-panel by someone with admin-powers ?
          This will also cause issues with Ruby scripts etc that use your user-path to save temp files etc...
            rogadude
            I just figured out you have to disable your anivirus software while you use Layout 2013
              Really? I don't have to do that with my AV software. Never have.
              • La DuFL Offline
                La DuF
                Me neither. Never have. And never will...
                • La DuFL Offline
                  La DuF
                  Hello, you SketchUppers !!
                  The problem I encountered with a "ç" in my username, causing LO to crash at startup has been solved by installing the latest LO version : 13.0.4812
                  • Mike LuceyM Offline
                    Mike Lucey
                    Thats good news. I'm currently doing an arch job and am finding LayOut 2013 very good indeed. No crashes and workflow is easy 👍
                      I'm glad that the main issue is resolved.
                      However, having non-ASCII characters like a cedilla in a User name or any folder path that SketchUp might want to access is a recipe for disaster.
                      On PCs the version of Ruby shipped with SketchUp is known to have issues with such strings in its File, Dir and IO operations [but MAC works OK, as do newer Ruby versions which are sadly unavailable for us to use via the current API].
                      So on a PC...
                      File.exist?("C:/Users/TIG/AppData/Local/Temp/Francois.dat")
                      will return false if it does not exist... AND true if it exists.
                      BUT with the cedilla in the path...
                      File.exist?("C:/Users/TIG/AppData/Local/Temp/François.dat")
                      will return false if it does not exist... BUT also false if it exists !!!
                      Which is pretty useless !
                      So be prepared that from time to time you might get illogical results from some Plugins...
                      An update of SketchUp's Ruby is long overdue... this fundamental issue with Ruby's old PC version is a pain...
                      • 2 / 2
