    Escaping Out of Eraser
    6 Posts 4 Posters 547 Views 4 Watching
    • cwmunroC Offline
      cwmunro
      Is anyone else having issues with the Eraser Tool?
      Ever since I upgraded to SU 2013, when I'm using the erasure tool, the Escape key doesn't work anymore.
      Has any one else noticed this?
      C W Munro
      Professional Building Designer
      http://www.thealaddincompany.com
        ESC didn't exit the 'Erase Tool' in v8 either...
        Press <spacebar> [or any other tool shortcut etc] to exit the Tool...
        • massimoM Offline
          massimo Moderator
          Perhaps he meant: pick the eraser tool-->select some edges by holding down left mouse button-->press esc to deselect without deleting?
          Anyway I don't have SU2013 atm so I cannot test if it works.
            If you activate the Eraser Tool and wipe over several edges while keeping the mouse-button pressed-down, then those edges will select - the selection increases with each highlighted edge - on releasing the mouse-button all selected edges will be erased.
            You then have to use Undo to go back one step and un-erase them.
            BUT if you were to press ESC while still holding down the mouse-button, then the previously selected edges will deselect, and therefore they do not erase when you release the mouse-button.
            This works in v2103 the same way as it does in v8...
            • massimoM Offline
              massimo Moderator
              Ok, thanks for testing, TIG. πŸ˜„
                It works as TIG described for me.
