    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Trees in vray 1.6
    renderpluginsextensions
    7 Posts 5 Posters 1.4k Views 5 Watching
      Deluxe78
      which trees are you using in vray 1.6 (proxies)?. Evermotion trees or?
      /Soeren
      • V Offline
        valerostudio
        I make my trees using OnyTree. There is a tutorial up on the Chaos site on my workflow. The thing I like about Onyx is that I can export direct to OBJ and use the ply2vrmesh converter to make the vrmesh file. No need for Max or Blender on the super hipoly stuff.
        If you use Evermotion trees, you need VRay for Max so you can make the vrmesh file.
        I have also put together a tutorial on the Chaos site on how to make a mesh from Blender, so if you can get it imported into Blender, you can make a mesh of it.
          I use X-Frog. They also offer many formats for their trees, such as obj or 3ds.
            Deluxe78
            Thanks valerostudio for you answer...
            I have i look at OnyTree. I can't find tutorials at chaos site. Can you sent a link? πŸ˜„
              ceollar
              I found the information on the ply2vrmesh converter .. ty
              I'm interested in your tutorial on blender as well but i've unable to locate it on the Chaos site... do you have a link possibly?
              ty
              • andybotA Offline
                andybot
                It's in the forum there, you have to be registered to access it.
                http://forums.chaosgroup.com/showthread.php?72774-Matt-s-OnyxTree-and-Ply2Vrmesh-Proxy-Workflow
                  ceollar
                  still stuck... can't seem to figure out how to access the material id's on the mesh proxy once its in sketchup
