    BuildEdge Plan Free serial nr missing
    17 Posts 7 Posters 7.7k Views 7 Watching
    • H Offline
      hetjo
      Hello, i've recently downloaded a plugin named "BuildEdge Plan Free" announced @ the latest CATCHUP, nº18 from the "sketchucation plugin store" but it keeps asking me for a serial number that i don't have and there is no info about it either in sketchucation site or Buildedge site.
      Could someone help me with this issue?
      Thanks,
      Hetjo
        Contact the tool's authors through their web-site...
        I thought the 'free' licensing was self-explanatory...
        Perhaps not.
        • aarondietzenA Offline
          aarondietzen
          Hi Hugo,
          Hopefully we have gotten you up and running, but for those who may stumble across this topic, BuildEdge PLAN can be installed and run in a "free" mode with limited functionality. At any point, you can choose to upgrade to a full seat from within the software, which will prompt you for an authorization code.
          We have been seeing an issue or two with the RBZ installations and upgrades via the Extension Warehouse, which I believe was the core of your problem.
          Hopefully all is running smoothly at this point!
          Thanks,
          Aaron
          "Imagination is more important than knowledge..."
          - Albert Einstein
          • O Offline
            omar tolba
            not free........ believe me
            what can i do now ?????
              Perhaps start by explaining your problem in a way that we can understand, rather than us having to make guesses 😒
                aarondietzen
                ... Yeah... what TIG said.
                Happy to help, when I know what the problem is!
                - Albert Einstein
                  tony bombata
                  I have sandboxie running on my system, and the plugin will not load unless I disable the sandboxie service completely. With any element of sandboxie running [executable or service] it will give a "license validation failed due to sandbox detection" message.That may be your issue; that buildedge will not start if any sort of sandbox is present on your system
                    @Tony
                    Please explain what 'sandboxie' is ?
                    I assume you do not mean the native Sandbox tools ?
                    Why do you need this mystery tool loading/running ?
                    What does it do?
                    Presumably it is clashing with the license validation process...
                    Why would it?
                    • O Offline
                      omar tolba
                      sir tig
                      the problem is .... there is no serial number or full version of this plugin (buildedge plan 2.0)
                      just i wnat to know if you could help me ti get one ....
                      thnq
                        tony bombata
                        @tig said:
                        @Tony
                        What does it do?
                        Why would it?
                        sorry for my late response
                        this is sandboxie
                        http://www.sandboxie.com/
                        http://www.sandboxie.com/index.php?FrequentlyAskedQuestions#WhatIsSandboxie
                        it has to be fully deactivated - service also, or buildedge plan will not run . these are the messages that pop up
                          So now I understand... ☀
                          You have a program running that stops other programs changing things on your PC, accessing the Internet etc.
                          So when this tool tries to access the license data it fails and can't run!
                          That is how you currently have your system set up - it is doing what you have told it...
                          It is not an issue with SketchUp or BuildEdge - its with 'Sandboxie'.
                          [stupid-name 😒 ]
                          This 'Sandboxie' has several known 'program clashes' listed in its FAQ pages...
                          Do you have any of those which might be exacerbating the issues here?
                          Perhaps you need to contact their support about this... 😕
                          I am surprised that 'Sandboxie' does not have a 'white-list' where you can 'exempt' certain processes from its seemingly very draconian regime???
                          I note that registered users of 'Sandboxie' seem to be able to run [a "forced"?] program to work not under the supervision of 'Sandboxie'. 😕
                          In that case try and 'exempt' SketchUp.exe etc... and see if that helps...
                          BUT perhaps its 'free version' lacks this most important of nuances...
                          If you are not registered, but want the 'protection' of a tool that seems to me to do more harm than good [!]... then it's your call... 😒
                            aarondietzen
                            Hi Tony,
                            TIG has pretty much covered this. Sandboxie prevents our software from authorizing.
                            Sorry!
                            - Albert Einstein
                            • G Offline
                              gentmangaga
                              Who can send me a serial number of BuildEdge Plan Free2.26?
                              TANKS,
                              ANDO
                              • Z Offline
                                zhulaojianke
                                I have a registered “Sandboxie” (an authorised edition), and I have bought the "Buildedge Plan" too. When the Sandboxie is running, the Buildedge is really not working! That's a really terrible matter.
                                  Read earlier posts in this thread.
                                  This has been covered ad nauseam...
                                  Sandboxie breaks this tool, and several other legit tools too.
                                  It is not the fault of these innocent tools, it is a problem entirely created by Sandboxie - please take it up with them... and get it sorted that way !
                                  • Z Offline
                                    zhulaojianke
                                    @aarondietzen said:
                                    Hi Tony,
                                    Sorry!
                                    I have reinstall win7 and reinstall sketchup and buildedge,
                                    I have uninstall sandboxie and it can run well, but when I input my serial number, it reply "Activation not allowed"! Anyone can help me?
                                      aarondietzen
                                      @zhulaojianke said:
                                      @aarondietzen said:
                                      Hi Tony,
                                      Sorry!
                                      If you have removed the sandbox tool, the best bet is to uninstall and reinstall BuildEdge PLAN. If you need a hand with this, the best plan is to contact our Help Desk at http://www.buildedge.com/support
                                      They will be able to walk you through the steps of reinstalling and get you back up and running.
                                      Thanks!
                                      Aaron
                                      - Albert Einstein
