    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 218.5k Views 79 Watching
    • K Offline
      kaas
      @ppoublan said:
      Hi Max,Could you post tree sample (skp) here in order to try to debug ? I was not able to reproduce the problem. Will do more tests.
      Hi Pascal, Just installed and tried the new plugin. Tried a few trees and can't reproduce the problem as well...Strange.. Will try more after I'm back from a trip abroad.
      Max
        jaceguay
        Very nice plugin, Thanks. All I need now itΒ΄s a people maker πŸ’š
        • bigstickB Offline
          bigstick
          Great work with the updated version Pascal!
          One suggestion however, when inserting multiple instances of the same plant/tree, what would be very cool would be an option in the 'Settings' dialog to randomly scale and rotate each new instance.
          With 3D plants, you can naturally get a degree of variation just by rotating and scaling components. The benefit of this is that it works with instancing for render engines, and keeps the file size down πŸ˜„
          • Bob JamesB Offline
            Bob James
            Totally, unequivocally, without question, absolutely OUTSTANDING 😍
            Note: Does not work if loaded into "additional folder". Needs to reside in the SU standard plugin location.
              dtrarch
              Great work Pascal
              A quantum leap for in-SU bushing up.
              Really quite amazing and only 10 Euro.
              πŸ‘ πŸ‘ πŸ‘
              Thank you β˜€
              dtr
              • ppoublanP Offline
                ppoublan
                Hi Bob,
                Thanks for your support. Yes you're right regarding plugin files location that needs to stay within default Sketchup Plugins dir. I started to make changes to fix that, but was blocked by limits of .rbs files (scrambled scripts) that does not work the same way as non scrambled scripts with ruby Files/Dirs functions. Hope to find a workaround for future versions. Will have to get help from the developers forum experts...
                Yours
                Pascal
                • ppoublanP Offline
                  ppoublan
                  This is the way it works. When you place multiple trees, or duplicate (right click a tree to access this feature), new instances are randomly rotated around their z axis and randomly scaled. The only thing is that the "amplitude" of scale cant be chosen.
                  +1 on my "todo" list
                  Yours
                  Pascal
                    lebsays
                    Just got this PLugin today... and it may be my favorite ever!!! I'm always struggling to find good trees when I'm modeling landscapes.
                    Can I turn the grass proxy on and off?
                    If the grass is turned on proxy will it render in photo-realistic renderers?
                    • ppoublanP Offline
                      ppoublan
                      Yes, grass is just handled like other trees and plants
                      No. But :
                      • renders that can use SU components will only take one copy/export of one grass and use it to build all the grass plants into the final render.
                      • for those not taking into account SU components, you may sometimes "tcheat" them by exporting once the grass object and separately the components places/scales (like for Octane now).
                        Check the forum of your prefered render to learn more on that.
                        Yours
                        Pascal
                        matt.gordon320
                        This plugin is absolutely amazing, a steal at 10 euro, and once of my top favorites! I wanted to throw a feature request out there that might be a little odd (or specialist) but figured it might be helpful for certain types of plants.
                        I'd love to see an eventual option for root systems, and especially on option for Aerial root systems like on the mangrove or banyan trees.
                        I do a lot of work in China's more tropical regions, and the clients would absolutely love local species in the models.
                        Thanks again for an incredible plugin!
                        • ppoublanP Offline
                          ppoublan
                          Hi Matt,
                          This is a good idea. I've seen this feature in more complex trees/plants generators.
                          I will look how to develop it, but it can take me long. Will try.
                          A kind of cheat/workaround to achieve this with the current version may be :
                          • create your root system as a second tree
                          • when happy with the result, flip it vertically, scale, and place under the first tree.
                          Here is an example :
                          Yours
                          Pascal
                            Works fine with LightUp! β˜€
                            And the fabulous Rail road system by Eneroth! β˜€
                              laudhi
                              i wish there is more option for vine/ivy.it will be amazing.... πŸ˜›
                              • ppoublanP Offline
                                ppoublan
                                Hi Laudhi,
                                Have you checked the Ivy tool from pierreden publihed in this forum ? I'm also using it and maybe it will allow you to achieve what you want.
                                Regarding 3D Tree Maker, you can use existing parameters to make "ivy like" trees. Let me know if they are any others you are thinking of ?
                                but it is not interactive (like Ivy) and does not take into account existing objects in the model, as 3D Tree Maker is only based on predefined parameters.
                                I think that both tools are complementary.
                                Yours
                                Pascal
                                  laudhi
                                  [attachment=0:kzqk1sgm]<!-- ia0 -->Capture.JPG<!-- ia0 -->[/attachment:kzqk1sgm][/quote]
                                  I'm just curious if there are plans for vines, there may be an easier way to make vines on the pole ...
                                  Your plugin is amazing, worth to buy the pro version.... πŸ‘
                                    rubenamaroh
                                    Help!!!
                                    I can't run this ruby, the program display in "Plugins" folder but dont display
                                    right next to the arrow the window options " New" , "License" and "About", whats wrong?
                                    Thanks.
                                    • TIGT Online
                                      Have you got available, and then activated its Toolbar ?
                                      How did you 'install' it ?
                                      • deaneauD Offline
                                        deaneau
                                        hi TIG
                                        i have the same problem in 2013
                                        in the menue appear only 3d ArcStudio.
                                        i have installed via sketchucation pluginstore plugin.
                                        if i try to open the toolbar this will not show in the windows.
                                        regards dean
                                        MADE, BORN AND LIVING IN BERLIN
                                        Big Thank You to all Programmers
                                        Some German words are so long that they have a perspective. M.Twain
                                        • ppoublanP Offline
                                          ppoublan
                                          Dear all,
                                          Just got an error with one of the version published, that did not work on SU8 nor SU2013.
                                          Pushed the last one (1.10.11) on Sketchucation and my website.
                                          Should load and setup menus now on all SU versions.
                                          Let me know if you discover other errors.
                                          Pascal
                                          • deaneauD Offline
                                            deaneau
                                            @ppoublan said:
                                            Dear all,
                                            Pascal
                                            Hello Pascal,
                                            this work now in 2013
                                            thank you for your fast respond.
                                            regards dean
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
