    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 259.9k Views 79 Watching
    • L
      lebsays
      Just got this PLugin today... and it may be my favorite ever!!! I'm always struggling to find good trees when I'm modeling landscapes.
      Can I turn the grass proxy on and off?
      If the grass is turned on proxy will it render in photo-realistic renderers?
      • ppoublanP
        ppoublan
        Yes, grass is just handled like other trees and plants
        No. But :
        • renders that can use SU components will only take one copy/export of one grass and use it to build all the grass plants into the final render.
        • for those not taking into account SU components, you may sometimes "tcheat" them by exporting once the grass object and separately the components places/scales (like for Octane now).
          Check the forum of your prefered render to learn more on that.
          Yours
          Pascal
          matt.gordon320
          This plugin is absolutely amazing, a steal at 10 euro, and once of my top favorites! I wanted to throw a feature request out there that might be a little odd (or specialist) but figured it might be helpful for certain types of plants.
          I'd love to see an eventual option for root systems, and especially on option for Aerial root systems like on the mangrove or banyan trees.
          I do a lot of work in China's more tropical regions, and the clients would absolutely love local species in the models.
          Thanks again for an incredible plugin!
          • ppoublanP
            ppoublan
            Hi Matt,
            This is a good idea. I've seen this feature in more complex trees/plants generators.
            I will look how to develop it, but it can take me long. Will try.
            A kind of cheat/workaround to achieve this with the current version may be :
            • create your root system as a second tree
            • when happy with the result, flip it vertically, scale, and place under the first tree.
            Here is an example :
            Yours
            Pascal
              Works fine with LightUp! β˜€
              And the fabulous Rail road system by Eneroth! β˜€
              • L
                laudhi
                i wish there is more option for vine/ivy.it will be amazing.... πŸ˜›
                • ppoublanP
                  ppoublan
                  Hi Laudhi,
                  Have you checked the Ivy tool from pierreden publihed in this forum ? I'm also using it and maybe it will allow you to achieve what you want.
                  Regarding 3D Tree Maker, you can use existing parameters to make "ivy like" trees. Let me know if they are any others you are thinking of ?
                  but it is not interactive (like Ivy) and does not take into account existing objects in the model, as 3D Tree Maker is only based on predefined parameters.
                  I think that both tools are complementary.
                  Yours
                  Pascal
                  • L
                    laudhi
                    [attachment=0:kzqk1sgm]<!-- ia0 -->Capture.JPG<!-- ia0 -->[/attachment:kzqk1sgm][/quote]
                    I'm just curious if there are plans for vines, there may be an easier way to make vines on the pole ...
                    Your plugin is amazing, worth to buy the pro version.... πŸ‘
                      rubenamaroh
                      Help!!!
                      I can't run this ruby, the program display in "Plugins" folder but dont display
                      right next to the arrow the window options " New" , "License" and "About", whats wrong?
                      Thanks.
                        Have you got available, and then activated its Toolbar ?
                        How did you 'install' it ?
                        • deaneauD
                          deaneau
                          hi TIG
                          i have the same problem in 2013
                          in the menue appear only 3d ArcStudio.
                          i have installed via sketchucation pluginstore plugin.
                          if i try to open the toolbar this will not show in the windows.
                          regards dean
                          • ppoublanP
                            ppoublan
                            Dear all,
                            Just got an error with one of the version published, that did not work on SU8 nor SU2013.
                            Pushed the last one (1.10.11) on Sketchucation and my website.
                            Should load and setup menus now on all SU versions.
                            Let me know if you discover other errors.
                            Pascal
                            • deaneauD
                              deaneau
                              @ppoublan said:
                              Dear all,
                              Pascal
                              Hello Pascal,
                              this work now in 2013
                              thank you for your fast respond.
                              regards dean
                                Jorgensen
                                Hi Pascal
                                I have just purchased the plugin (version 1.10.07) and installed it in SU 8 pro.
                                I get an error when I try edit a tree πŸ˜•
                                Do you know how I can avoid this?
                                [EDIT]
                                It seems to work if I just press ok.
                                Is it somehow possible to speedup the redraw process - I'll have to wait several minutes before the tree is updated πŸ˜•
                                I guess it's a limitation of Sketchup, but I find the plugin hard to use then I have to wait this long every time πŸ˜•
                                • OxerO
                                  Oxer
                                  I came back to the v1.06.04 because this version draws the trees in few seconds (between 3 and 8 seconds in my computer), but there is one inconvenient, you lose the feature make grass and other features related with the Materials, present in the last version.
                                  • ppoublanP
                                    ppoublan
                                    Hi Jorgensen,
                                    Did you try with the last version : 1.10.11 that is published in the Plugin store here or from this link :
                                    http://www.3darcstudio.com/downloads/3darcstudiotree/3darcstudio_tree_v1.10.11.rbz
                                    Download the file,
                                    Setup using standard SU rbz extension install
                                    After install, exit and restart SU
                                    Did the error still occur ?
                                    If yes let me know and we will try other tests. First time I see it, so I need more investigation.
                                    Does anybody here also got the same error ?
                                    Regarding speed:
                                    • on 2 different PCs I'm using, drawing a tree is less than 30s for the more complex one and less than 5seconds for the standard generic tree.
                                    • be sure you close the Sketchup Outliner window: this is the main cause of slowness I have seen as SU try to refresh outliner for all geometry changes within scripts
                                    • ensure also that additional plugins that checks for geometry changes (like render viewport) are not running while you are drawing a tree as they will try to update
                                    • the script also runs a little bit faster on SU 2014.
                                    Yours
                                    Pascal
                                    • ppoublanP
                                      ppoublan
                                      Dear all,
                                      another tip to use tree maker with better performance, to place trees within large models:
                                      • I build/change configuration of the tree in an new empty Sketchup model
                                      • When I'm happy with the result, I convert it to proxy with the integrated tree maker proxy function
                                      • Then I copy/paste this component (which is small) to the final model where I can make instances
                                      • When all trees are in place and I want to render, i use "redraw all" in the final model, this can take some time if many trees, but have to do it only once before rendering
                                      • I also use the proxies features of the renders when available (Thea, Octane, ...)
                                        Yours
                                        Pascal
                                      • ppoublanP
                                        ppoublan
                                        Hi Oxer,
                                        The main difference is that the old version is making SU groups, not components.
                                        Using components is really more efficient when you need to place many instances, and you got also a SU file that is lighter.
                                        So yes time to draw with the new version is a little bit more slow to draw one tree (on PC), but a lot much faster to redraw 20 or more trees as only the component is rebuild, not all instances.
                                        This was the reason I make this change to integrate features like grass.
                                        But as I really have acceptable performance on PC/2014 (few seconds to draw most of the trees), maybe i have a specific issue of speed with Mac.
                                        I will try to add few time logs to the next version so see what is slowing down the most.
                                        Yours
                                        Pascal
                                        • OxerO
                                          Oxer
                                          I found a plugin that it makes slow down the drawing of trees, BGSketchup_Composants.rb, with this plugin installed the drawing of tree02:Cypress takes 47 seconds, without the plugin installed the drawing takes 12 seconds, other example, the drawing of tree00:Default Generic Tree takes 6 seconds without plugin, with the plugin installed 55 seconds.
                                          Mac OSX 10.9.4 & SU2014 with Tree Maker v1.10.11
                                            Jorgensen
                                            I tried to removed all plugins, and the script seems to run ok - but I still get the error.
                                            If I install octane render, the problem happens again (things take very long time), even with the Octane Viewport closed.
                                            So it seems that octane render somehow sesses things up in my Sketchup.
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
