    Hardware
    renderpluginsextensions
    8 Posts 4 Posters 780 Views 4 Watching
    • IceTI Offline
      IceT
      Hello,
      If you read this please post a reply with your hardware info and your opinion.
      I am planing on buying a new computer therfore I would like to hear your opinion/thoughts about anything related to this.
      So currently I am looking at:
      • i7-3770 # of cores 4 # of threads 8 clock speed 3.4 ghz max turbo frequency 3.9 ghz intel smart cache 8 mb
      • MSI GeForce GTX 680 OC, 2GB DDR5 (256 Bit), HDMI, DP, DVI
      • asrock/gigabyte/msi s1155 B75 ddr3 usb3 sata2 matx
      • 8192mb, kingston technology 2x4gb 1600mhz ddr3 non-ecc cl9 dimm kit2 HyperX
      • 1tb, wd western digital caviar green 3. 5" sata3 ip 64mb
      • sony opti 5280s, dl dvdrw 24x black sata
      • jns output power 750 watts 14cm fan
      • gigabit, 10/100/1000 mb/s
      • hd5. 1, high definion audio 5.1 channel
      I might be looking at GTX 660 as well.
      How much RAM would be the best case for vray? I read that windows can only use up to 8 GB of RAM.
      Also I forgot to add that I'm planing on using it for animations as well as image renders.
      Have a nice day!
      • V Offline
        valerostudio
        The i7's are the best way to go for rendering horsepower. I have a 6 core (12 threads) at home and it was well worth the few extra bucks to get the additional threads. At work, I have an Intel Xeon E5-2665 @ 2.4Ghz which gives me 16 threads but is really only a little faster than my i7 at home.
        • IceTI Offline
          IceT
          Do you have Intel Core i7-3930K at home? Or 3770? And what about your video card and RAM?
          Are you just rendering images or also videos?
          Thank you!
          • IceTI Offline
            IceT
            Anyone else please?
            • panixiaP Offline
              panixia
              seriously?? everyone i know says multiple xeon is way faster than i7.. but i don't know.
              i only work on 3 computers and they are all quad core i7.
              actually i've never seen a couple of xeon in action.. i'm curious..
              • V Offline
                valerostudio
                This is the resource I used when building my machine http://www.cpubenchmark.net/
                • IceTI Offline
                  IceT
                  Ok thank you. I'm using it as well when I want to compare things.
                  FOR EVERYONE: Do you have a SSD? How does it help vray and does it help rendering as well? Does/Could it play a similar role like RAM just a bit slower?
                  And what are you experience with SSD?
                  Thank you in advance.
                  • jiminy-billy-bobJ Offline
                    jiminy-billy-bob
                    It helps :
                    • When loading heavy bitmaps at the beginning of the rendering.
                    • When you run out of memory, and vray has to swap a lot on the hard drive. (It's easy to see, your CPU is not at 100% in that case. It's limited by the HDD)
